Excellent.DuckRyder wrote:That is true, I really feel like the fact its run very little and predominately at low speed is very much in your favor. I'm glad the cam was already broken in
Thanks for appreciating my posts! And I hope your fore cast on #50's awesomeness plays out that way. It'll certainly be an unusual vehicle!DuckRyder wrote:You have done all the hard work, including the paying for it, but we've read so many detailed and well thought out post with pictures I almost feel like I've been there for the whole thing! I think its going to be an awesome truck when you are finished.
Indeed!DuckRyder wrote:Just keep that attitude and you will be fine! Gotta break a few eggs to make an omelet and all that.
That reminds me of how I used to feel when waxing #50, years ago, despite its crusty, rusted out bed seam!DuckRyder wrote:BTW, did you guys know that on myth-busters last night they did in fact polish poop? Not that that has anything to do with this...
Indeed! I've read that FEs are special animals, and it would be a major project for me.DuckRyder wrote:I sort of figured that if you wanted to actually build a motor, you'd not have HAD this one built!It is a pretty steep learning curve, particularly on an FE, and it isn't for everyone.
I see! Okay, thanks for explaining that.DuckRyder wrote:To help protect the cam, because it is going to end up being washed off during the clean up.robroy wrote: What's the reason behind using diesel oil or a zinc/moly additive?
Excellent, I'll keep an eye on it but not be ultra careful about that, thanks! It's not super humid out there in the garage.DuckRyder wrote:Brake cleaner evaporates very quickly, I personally do not think it will be a problem unless it is VERY humid where it is stored.robroy wrote: If rusting is a concern, would it make sense to flush it out as well as possible, then be sure to spray some WD-40 all over before leaving it for the night?
Okay, great! You know, since it looked far stronger (with its wide body), I went ahead and ordered the ARP shaft anyways. It won't hurt to have a high quality spare (the Melling).DuckRyder wrote:Some where in there you mentioned that they used a Melling pump drive, that should be fine, no need for the ARP.
Although it's probably silly to compare the quality of a part based on its price, I did note that the ARP was $18 while the Melling was $7. Based on its appearance and extra cost, maybe the ARP is a more supreme part.
Hey I like the story about sanding the bearing! That is truly classic.
Robert, thanks again for your excellent reply!
Robroy
