Ok, now that I have my highboy, I need to add power steering. What is the quickest way to do this?
Brett
Highboy power steering set up...
Moderator: Doug Comer
- heep70
re: Highboy power steering set up...
I installed it this way. http://www.fordification.com/powersteering4wd.htm
I was pretty easy I thought. I can answer questions if needed.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
if i cant find a 78-79 power steering box (doubt i will) then i plan on doing this swap...once you get what you need I dont think it would be to hard I might have a few Q's your way heep after i try one more yard c(has some 4x4's) to get let down again ![Very Happy :D](./images/smilies/icon_biggrin.gif)
"Gas' Guzzler fer life" "Southern Pride""It's not what you buy it's what you build"
the 36's are geting hard to turn
and sence i plan to go bigger tires , and about to do other frame and body work I figure might aswell I'm gona use a 69' 2wd saginaw box
I just finished a p/s conversion on my 69 f250 with a four bolt p/s box from a 76. I purchased the pump,lines, and steering box from advance auto parts. I thought it was a lot of work but well worth it. I would suggest bringing the truck down for a few days to do it right. It was surely worth the money if you plan on driving the truck everyday or just on weekends. I could not get the smile off my face a week straight after the conversion. ![Very Happy :D](./images/smilies/icon_biggrin.gif)
1969 FORD F250 4X4
