Lap belt torx
OldRedFord
Lap belt torx
Post by OldRedFord »
What size torx bit do I need to take the lap bets out? Need to do some welding.
I have a T55 torx but thats too big.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
Re: Lap belt torx
its a t 50 i have broken three of them.
OldRedFord
Re: Lap belt torx
Thanks!
Three of the bolts or three of the sockets?
Tim
Re: Lap belt torx
sockets. i think they were made you know where. but this last one was guarteed if i can find the reciept.
cep62
Re: Lap belt torx
Post by cep62 »
OldRedFord wrote:Need to do some welding.
If you end up stripping the torx on the bolt , seeing as you have to do some welding anyway.
Get a large nut and weld it through the center to the head of the bolt.
Then you can get a socket and impact it off , the heat also will help in removal.
Put a wet rag over the fuel filler so there's no big kaboom. :D
