Instrument Panel Gauges
Re: Instrument Panel Gauges
Ok, thanks!
My goal in life is to be as good a person as my dog already thinks I am!
1968 F-100 Longbed 390/C6
I just got the truck back doesn't look like any of the gauges work!
Doesn't look that way. He said the only that didn't work was the temp gauge but I drove the thing home and the fuel gauge read 3/4 of a tank and I ran out of gas a block from home!
instrument panel voltage regulator?
This is the reply I got from the kid who worked on my truck.
I wouldnt know where to start with the gauges though, because you have voltage to the gauges, and a good ground at the gauges. I checked out a book at the public library containing the trucks wiring diagram. According to the diagram, the wiring is correct. The sensors were replaced also, so I dont know what it could be.
Any ideas??
Any ideas??
ok here is where i read the thing about 5 volts. i guess the ipvr gives out a 5 volt pulse. for the fuel gauge to work properly. this is what i have tiem to read and check out right now. http://www.fordification.com/tech/fuel- ... -units.htm
