![Help :help:](./images/smilies/icon_help.gif)
what do you guys do for heat?
My 67 f100 is heat challenged currently and I need to change that. Anyone used a newer heating system into our older trucks. Ive got a complete HVAC system from a 90 F250 I was thinking of modifying to squeeze in but wanted opinions. ![Help :help:](./images/smilies/icon_help.gif)
67 F100 Stepside
302 5.0 V-8, C-4 Trans
Ford Certified Technician, UTI Graduate
Re: what do you guys do for heat?
i havent read of anyone using a different heater in these trucks. for the a/c option i don't know i havent heard of it but making it work would be a different story. i think the 73-79 factory a/c would be a more closer solution to fix the a/c problem. but so would a aftermarket under dash unit.
what is wrong with your current heater? is everything on it? how many rust holes are letting the cold in? is the heater valve stuck half open? is the heater core old and plugged up? what temperature thermostat is in your engine?
what heater?
not really interested in the AC unit, just heater.
67 F100 Stepside
- papabug71
Are you saying your truck was ordered without heat or the factory heater dosent work very well? It might have the econo heater in it. I think it consisted of a on/off switch for the blower.
![Image](http://i42.photobucket.com/albums/e340/bigmacdak/papabug71sig2-1.jpg)
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
i have no heater. there are controls for it there and some venting but the box and all others parts needed are MIA.
67 F100 Stepside
- austin
i would look for some replacment heater parts if it was me check ebay
The stock heater setup will run you out of the cab as long as everything is functioning properly. If it was me I wouldn't go trying to fit something in there that was never meant to be, when you can easily find the correct pieces and just bolt them in. Since heater boxes aren't something that sell very often, I'd imagine there are many people here on the forums with parts trucks who'd let you have one pretty inexpensively. ![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
- knightfire83
Replace your heater core if it is old, even if it is not leaking it will have reduced flow from build up inside. My truck had decent heat when I first got it. After the core started leaking and got replaced, the heater will now roast you out within 5 minutes. Amazing difference.
You can also upgrade your blower fan: http://www.fordification.com/forum/view ... =6&t=41940
Fix any levers and doors that are not working in your heater box.
Clean out any leaves and debris on the intake side of your heater box.
Fix or temporarily plug rusted cab corners and floor boards.
Replace the weatherstripping around your doors.
Any of these things will greatly improve the heat inside your cab.
![Image](http://www.easyfreesmileys.com/smileys/freddo2.gif)
1970 Ford F250 4x4 ~ Sold.
Another member (
) posted a link to a bronco forum that the members replaced there blower motors with ones from a 78 Chevy pickup. Some used the wheel from the chevy some didn't. Both applications reported amazing differences. I ordered the stuff from Autozone and am going to give it a whirl. I'm not to happy
about using the GM parts but we'll see.
Doug
![Crying :cry:](./images/smilies/icon_cry.gif)
Doug
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
- BobbyFord
Like Keith said, a stock heater in good working order will toast you. Cooling system maintenance is key to having a good heating system. Corrosion and mineral build-up is hard enough on a heater but sometimes guys will use Stop-leak to fix a radiator pinhole and wind up sealing up their heater core without knowing it. Stop-leak should only be used in extreme emergencies.
- austin
thats a great thread knightfire83 i tought about doing somthing like that i thought i was going to be the first but it great that you did it first so i have a good diagram to follow
so scrounging thru the boxes of extra parts that i had i ran across the heater box for my truck from the previous owner. i didnt recognize it until i found a photo of what one for my truck looked like. i got it all set up inside the cab, but do you happen to have a photo or description of what the coolant lines in the engine bay go?
67 F100 Stepside
- fireguywtc
Here is my pickup and the two smaller hoses on the passenger side of the engine bay are the heater hoses, one goes to the top of the intake manifold and the other runs to the water pump. The hose that runs from the heater to the intake is were my heater valve has gone since I have owned it.
![Image](http://i439.photobucket.com/albums/qq111/fireguywtc/DSCF1815.jpg?t=1259898413)
Bill
- qmcdugan
As I understand this is what it is suppose to look like. Mine does not look like this yet.
![Image](http://i589.photobucket.com/albums/ss340/qmcdugan/70f250rtengbay.jpg)
![Image](http://i589.photobucket.com/albums/ss340/qmcdugan/70f250ctrengbay.jpg)
70 F-100 Sport Custom, 84 Camaro SportCoupe
