what do you guys do for heat?
Re: what do you guys do for heat?
wow that is clean
ToughOldFord
Post by ToughOldFord »
Bill's pic shows the routing without the carb heater. The pics you posted show the heater installed and hooked up. They looked a little odd to be however, so I found this pic of mine, it's not the best pic, but you can see the "T" on mine is to the right near the control valve. I'm not 100% sure that mine is the stock method of doing it, I'm sure they both work fine, but I think mine looks less cluttered.
ToughOldFord
Looks like mine is not the correct way, I looked up the engine pics of that 358 mile Ford and found it coincides with the first pics:
70_F100
Post by 70_F100 »
qmcdugan wrote:As I understand this is what it is suppose to look like. Mine does not look like this yet.
I think the color of the engine is off a little bit... :D :D :D
JMcTurnan
Post by JMcTurnan »
Thats a beauty of an engine =P
yes the color is a shade or two light.
badboyzkustumz
Post by badboyzkustumz »
so i disassembled the heater box and cleaned that all up. took the core out and filled it with water, no leaks. then took it to work and put ran it on the coolant flush machine to eliminate any flow issues. the fan works fine as well as i hooked it up to a battery and it spins like it should. flat blacked the housing and put it all back together. my store (pep boys) actualld had the control valve in stock, grabbed that and some 5/8 heater hose and got it installed. only thing i need to do is get an adaptor to go from 5/8 tube to 3/4 tube. ive got a 302 in the truck and the one tube on the water pump is 3/4, not 5/8. no big deal. the truck still had the cables in it so i will get those attached. last question i have is the incoming air vent, where does it connect to? :fr:
67 F100 Stepside
302 5.0 V-8, C-4 Trans
Ford Certified Technician, UTI Graduate
knightfire83
Post by knightfire83 »
From a previous post by Jay's67F100:
1970 Ford F250 4x4 ~ Sold.
70_F100
Post by 70_F100 »
Fordman, did you just list that??? LOL!! :lol:
i listed it before i came onto the forums. it was a by chance this came up in this thread. so i thought i would post a link. i have a box full of these things.
70_F100
Post by 70_F100 »
:lol: I guess it was just fate!!! :lol:
badboyzkustumz
just bid on it fordman! thats the last piece/part i need to get this done.
67 F100 Stepside
i see someone bid i wasnt sure who it was. i was guessing it may have been someone on the forums. i think it was fate. i didnt do much ebaying today. it was cold outside. and i didnt want to get my hands wet in gasoline when it was cold outside.
cdeal28078
Post by cdeal28078 »
That is one thing I have never had a problem with is heat in my 71 F100. Always had plenty of heat. Now the defrost system could use some work. Works great on the center of the windshield but doesn't do squat for the sides of the windshield or the side windows. Long as you have the right thermostat and the heater core isn't blcoked these old trucks WILL run you out of the cab with heat. lol
Clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
