aod swap
meandad xlt
aod swap
Post by meandad xlt »
I read an old post (April) regarding a possible tutorial about an AOD install. Anything developed on that?
With gas going up, $3.10+ in Phoenix, it would be easier on the wallet with OD in Meandad.
Remember if you can't be good, be good at it!
1971 F100 Ranger XLT
1933 Ford Pickup (project)
you may need a different drive shaft. that depends on what your taking out i suppose. we probably need more info on what your doing to give you any help.
meandad xlt
re: aod swap
'71 F100, 2wd, 351W with C-4, shot bed
GT-Racer
re: aod swap
Post by GT-Racer »
I think, and I am no expert on this , that they are the same length. I have an aod from an 83 ford van and it is the same size as my 70's model c-4
'67 F100 2wd shortbed - Beginning restoration.
351w, 5-speed, 3:70 gears (someday)
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....:)
customcrewcab
re: aod swap
Post by customcrewcab »
where in phoenix are you? i am out in the east valley. i had an aod in my 70 shortbed and hated it for the most part. ended up putting a 5 speed in it. i like sticks more anyways. the yoke is the same on all three but i think you need a non lockup converter. thats what i had in mine.
i wouldn't think there would be too much too worry about then the bell housing should bolt up if both trannies are from the same size engine. one thing that may be different would be linkage and trans mount to cross member. the aod i have in my 93 and probably my 94 have a cable for the linkage. the cable just engages the tranny directly. if your unsure do some measuring on the rear mount on both trannies from front top mount and then across the bolts. thats all i can think of at the moment
customcrewcab
re: aod swap
you need the flex plate for the aod. that could be a problem since most aod are 50 oz 302 and 351 are 28 oz. i think you need a 157 tooth starter too. i think the later model 351 might be 50 oz.
willowbilly3
re: aod swap
Post by willowbilly3 »
I had a good article in hotrod a couple years back. I think the length may be real close. The 2 things to get right are the TV cable (some may call it a kick down, it isnt) adjustment and the shifter detents. One of the guys in the artice messed up 3 or 4 trannys before he realized his shifter was indexing the gear positions wrong on the tranny. Everyone knows about the TV cable, you have to adjust it with just a bit of free play. Find out and get it right or that will ruin a tranny too.
SVT522
re: aod swap
Post by SVT522 »
It was me that put an AOD into my '67 to replace the dead 5-speed. I've been busy retiring form the USAF and getting settled back home. The C-4 and AOD may be the same length. It depends on what the AOD came out of. Some of the trucks had a longer tail housing and output shaft. A C-6 tranny mount worked. I was able to use the driveshaft that was behind the 5-speed. Good luck and I'll try to answer any questions you might have.
SVT522
ASE Master Automotive & Medium/Heavy Truck Technician
"The Speed Bump" 1967 F100 - 466 "Cobrajet", C-6 trans, 4.11 Detroit Locker
1969 F100 4x4 - 360, NP435, Dana 21
1973 Mach1 - 351 CJ, C-6, 9-Inch
1996 SVT Cobra #522
1987 F-250 4X4
willowbilly3
re: aod swap
In my opinion you will probably be a little disappointed in the small gains that you get from all the effort. Consider; An average 1970ish shortbed with a stock 302 and C4 tranny will get maybe 15-16 average. Now take a 96ish 5.0(302) with the aod, plus computor controlled engine and lockup convertor and it will still only get 16-17.
SVT522
re: aod swap
Post by SVT522 »
My '67 with a fuel injected mustang 5.0 engine and an AOD has done 19.5 mpg with 4.11s in the rear.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
willowbilly3
re: aod swap
I would be interested in test method. Short term, like partial tank? Filled at the same gas pump under the same conditins? repeated more than once? Tailwind? Coming off the continental divide?
My 96 F-150 made 20+ on a couple tanks with a good tailwind. Exact same trip and turned into the wind, made 12. So I could say it made 20 plus but 15 1/2 was how most tanks went.
67effie
re: aod swap
Post by 67effie »
Well I am currently running a 93 5.0 with 300 HP 2400 stall and a C-6 tranny 3.50 gears and getting 15.77 miles per gallon. I am planning to install EFI, AOD and 3.73 gears. Also Lokar makes a kickdown cable that is used with a carb the TV cable is what it is called when it is used on a EFI motor.
If at first you don't succeed. Get another beer.
Jeremy
1972 F-100 - currently under going complete frame off restoration
1997 Mustang GT Convertible- (gone but not forgotten, damn unemployment)
1996 Saleen S281 #247
1988 - Coupe, OSP car sold to public NEW, under construction, 1 of 3 that was supposed to go to Saleen in 1988.
http://www.fordification.com/galleries/ ... ?album=270
willowbilly3
re: aod swap
You gonna run the lockup?
meandad xlt
re: aod swap
Meandad here,
thanks for all the good information. like our leader, Fordification, i am still in the construction phase so i am going to do more research on the swap. i will post what i find out.
to customcrewcab,
north phoenix, 32nd st & cactus area. pm me sometime.
