another ignition switch question
- randyvines
The blade connector on the side of the switch gives a momentary ground to the case when in the start position... what is connected to this I haven't found a thing that this does on the diagrams. Make me go hmm?
- randyvines
Re: another ignition switch question
Yes a 67 f100
possible momentary ground to dash warning lights? Ground to turn the lights on (momentarily) while cranking to let you know they work.
- knightfire83
This allows you to see if they are functioning and not burned out when you go to start up.
1970 Ford F250 4x4 ~ Sold.
- randyvines
what an incredible night; ignition switch replaced and dash lights fixed (corrosion on rheostat) makes for a huge mental step.
