electrical ghosts
Diesel72
electrical ghosts
Post by Diesel72 »
My head lights turn themselves on and off does anyone have any ideas. There is a fuse mounted on the passenger side kicker panel(a large square block with 3 wires) what would you call it other than a fuse no parts house or dealer can look it up?
Last edited by FORDification on Wed Apr 08, 2009 11:09 pm, edited 1 time in total.
Reason: Moved post to Electrical forum
Re: electrical ghosts
replace the headlight switch. that fuse block is for your cab over lights.
Thunderfoot
Post by Thunderfoot »
:yt:
The Headlight switch has a built in self-resetting circuit breaker. They get week over time and do this OR if you put aftermarket High Watt bulbs in the truck this switch will not handle the extra load causing this blinking to happen.
The thing on the passenger side is called a "circuit breaker"
Diesel72
Post by Diesel72 »
No not the breaker it has two wires this has three wires and it says it is a fuse but the dealer cannot find it on their data base the part number is C8TB-13A435-A
This is the piece you're talking about, and it's actually a relay, not a fuse or circuit breaker....and it has nothing to do with your problem.
As fordman and Thunderfoot stated, your problem is either with the headlight switch (the internal circuit breaker) or the dimmer switch. Replace the headlight switch. When others have reported symptoms exactly like yours, 98% of the time it's the headlight switch. The other 2% was the dimmer switch.
Thunderfoot
:yt: If the 3 wires are a Brown wire, a Black wire, and a Black/white striped wire going to it then it is the Relay for the marker lights. This is used on Camper Specials (for the front fender marker lights and the camper), and trucks that have roof lights and flat bed marker lights. Here is the wire diagram for it http://www.fordification.com/images/sch ... arkers.jpg you can also see the circuit breaker in line for it as well. This is all mounted on the passenger side of the truck under the dash, above the side vent.
Either way it wont effect your headlight any...
1982 flareside
Post by 1982 flareside »
Could be a dimmer switch.
Jeremy
1971 Ford F250 camper special 360 T18(old model) 4 speed 4.11 gears 2wd with 1969 doghouse soon to be daily driver FRANKENFORD
1982 Ford F150 flareside 300 T18(new model) 4 speed 4.11 gears 4wd Daily driver
Some people say my truck is ugly and all i say is "Beauty is in the eyes of the beholder.
