alternator wiring
diehardmark
alternator wiring
Post by diehardmark »
bought a ford f350 trying to restore.replaced alternator but noticed wiring on back is different.original was b f and g, new one has sta,field and bat,wired in what i thought was right now getting around 13 volts but after sitting for awhil over night.batt is dead.nothing is on do i have a short and would batt.disconect solve this on negative lead.im assuming b was for battery,f was field and g was ground right.thanks :fr:
Re: alternator wiring
i see. there are two ways to wire up the alternator for our trucks. one is for a gauge cluster in the dash. or for the half lights half gauges. the wiring diagrams are here if you neeed to see them. some of them are for dash lights and some are for gauges instead of lights. what year is your truck? do you have all gauges or half gauges and half lights? http://www.fordification.com/tech/schematics_h.htm
diehardmark
1967 f350 half gauge half lights
this is the diagram of how it should have been rewired. http://www.fordification.com/tech/wirin ... gauges.jpg
unless you didnt change the wiring around then it could be the alternator or a bad battery. you can take both to the parts stores to have them cheked to be sure they are good. or it may have a short in the wiring someplace and it is drawing the battery down.
68FORDJBM
Post by 68FORDJBM »
I'd like to completly re-wire all of the wiring between my alternator, voltage regulator and starter motor relay. Does anyone make a specific wiring harness for this application?
I'd build my own harness but where does one find the plugs and connectors that aren't in most auto parts stores. Does LMC or DC sell them?
basketcase0302
Post by basketcase0302 »
68FORDJBM
Post by 68FORDJBM »
Sweet! These sites are perfect and look to have what I was after.
Dragon
Post by Dragon »
Also as I said somewhere else our ignition switches had a recall because they would get flaky when shut off and burn up the wiring harness or just drain the battery
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
My Gallery
Spark test
