Good day Power By Ford 70 F250 4x4 and Dragon, thanks for your excellent replies!
Power By Ford 70 F250 4x4 wrote:Hello Robroy,you said you ended up with a march #p561, but I see you show a Tuff Stuff .Is that the one you got from March?
Yes it is! As you know, P561 is a March part number, not a Tuff Stuff number. March gets their hands on the Tuff Stuff parts, does unknown things to them (which might be nothing at all), and puts their own sticker on the box right over the Tuff Stuff sticker.
Under the March sticker I can read the original Tuff Stuff sticker on my box, and it reads, "70[685]9-BM," where [685] could be any one of 6, 8, or 5. I wish I could read the part through the March sticker better but it's not easy to see. I tried to peel the March sticker off but it's bringing everything with it (and making it even more illegible).
Power By Ford 70 F250 4x4 wrote:The alternator that I was looking at is Tuff Stuff #7078ndp.Are they the same?I appreciate the help.
I'm not sure! Considering that March may have put my P561 in a box other than the box they received it from Tuff Stuff in, I can't say for sure whether or not the part number I'm reading matches this alternator.
To be certain, I think your best option is to call March at 1-888-729-9070 and see if they'll tell you the Tuff Stuff part number that their P561 is based upon. Hopefully they will! And while you're at it, you may be able to determine exactly
what they do to update this alternator before reselling it, if anything.
Dragon wrote:I am an electrician and that does not make sense. a 200A fuse blows at 200A unless dual rated.
Okay, thanks for posting with this information Dragon!
Dragon wrote:A 200A resistive circuit, headlights radios and such has no surge an sudden discharge. Larger copper coils like Alternators that are not spinning and capacitors (condensers inside of dizzys are small ones) will require a fuze that is rated for surges. A 140 amp out put needs 140 amps of protection or the next higher fuse rating. Like 150.
Okay, thanks Dragon! I'll look in to my setup again then to make sure it's in compliance with your advice. I appreciate you adding in your expert thoughts on this!
Power By Ford 70 F250 4x4 and Dragon, thanks very much for your great replies!
Robroy
