Turn signal repair
Gen
Turn signal repair
Post by Gen »
Ok, I'm dying here. I can't seem to get the turn signal cam installed correctly. Here's what I'm working with.
Original turn cam:
Replacement aftermarket cam:
Steering column:
My issue is the replacement cam doesn't "exactly" match the original cam. The original cam has slots to accomodate the small sliding contacts. The aftermarket cam does not. Anyone install one of these yet? I could really use some help.
Thanks,
Gen
Re: Turn signal repair
i need to see the same side for both pieces.
Gen
Post by Gen »
That is the same side for both pieces. See my problem?
the metal prongs in the second picture should point down towards the steering column part of the tss.
Gen
Post by Gen »
I've tried that. What is hard to see in my picture is the the plastic nubbins in the same location as the sliding contact nubbins.
it should go right on and work. i am unsure why yours isnt. check out a few threads in the wiring section to see if you can find other posts about someone changing thiers. this is the first time i have heard of this. but i was looking at the above picture compared to the one i bought but havent installed yet. and mine doesnt have the pegs. i has a raised area the rasies both of the contact prongs on both sides. so it cant get caught up in the rest of the switch.
quantumleap
Post by quantumleap »
recently put one in and couldnt get it to go without shaving the plastic nubbies off...i think thats part of the self cancelling mechanism though...all in all...same situation as when i first installed it :dk:
Daniel--67' reg cab black shortbed/fe/4spd/ford 9
it turns out his was a aftermarket turn siganl switch cam so it wouldnt work properly with his switch. he ended up getting a new switch i think.
Gen
Post by Gen »
Haven't done anything yet except re-install the original broken switch. Still trying to decide what to do.
Later,
Gen
quantumleap
maybe pull a whole new(used) switch from a junkyard?
