ALTENATOR
Re: ALTENATOR
Install a 3g from a taurus, real simple and real good swap.
Don
Don
- heviarti
Re: ALTENATOR
DISCONNECT THE WIRE FROM YOUR CAPS LOCK... and then type like this. Read the one entitled 'alternator wiring conundrum' and if you feel savvy enough, install the Delcotron. Maybe not as easy as the 3G, but much more available, and more application extensible
Re: ALTENATOR
Why use a delcotron (i'm assuming 10/12si) when you can use a 3G??? 130 amp capable, damn near bulletproof, and readily available. Several threads on here about how to...
- ForingaMex
Re: ALTENATOR
Here is one of the threads you need to read through. I've done the 3G on mine and it looks and works great. http://www.fordification.com/forum/view ... =8&t=13062
-Jake
-02 Dodge Ram Quad Cab
-92 VW Beetle (Mexican)
- FreakysFords
Re: ALTENATOR
For me, the options would be:
1) 3G
2) 3G
3) 3G
OR if you're feeling really crazy, a 3G.
3G is super easy, readily available, super reliable and very clean.
Frank
1) 3G
2) 3G
3) 3G
Frank
Darlin 69 Ranger 390 4v, PS, DS II, disc front, 3G alternator, 67 mirror.
