tail/brake light wiring
so i got a set of 48 ford tail lights for my stepside. little cooler than the broken plastic ones i had right. well the new and old ones only have one power and one ground. im assuming that power from the tail lights and brake light both go into the one positive wire?
67 F100 Stepside
302 5.0 V-8, C-4 Trans
Ford Certified Technician, UTI Graduate
Re: tail/brake light wiring
you can try that but i dont know that it would work properly.
- ForingaMex
badboyzkustumz wrote:im assuming that power from the tail lights and brake light both go into the one positive wire?
The light should ground throught the housing onto the truck bed and both of the wires + leads. One of the two wires should be for the tail light and the other for the brake/turn-signal.
-Jake
-02 Dodge Ram Quad Cab
-92 VW Beetle (Mexican)
