That's the heavy-duty flasher as used on Camper Specials.
what is it
Re: what is it
Re: what is it
if that goes out will i lose turn signals and four way flashers?
cuz im looking for the heavy duty flasher and it is a camper special..
Re: what is it
sorry about the email thing I just signed up today..didnt know.
very cool site by the way..
greg
greg
Re: what is it
this diagram doesnt seem right fo rthis type of hazard can but it may be. this diagram shows if the flasher can is bad you will only lose the hazard lights. http://www.fordification.com/tech/wirin ... ghts02.jpg
if you have brake lights then your turn signals are a different problem. most fo these trucks have problems in the turn signal switches when multiple lights wont work.
Re: what is it
I dont have brake lights or turn signals or emergency flashers.
i do have running lights..
thanks Greg
thanks Greg
- Wes
Re: what is it
yes the heavy duty flasher could be causing those 3 functions from working. The emergency flasher switch on the 67's seems to be a weak spot.
The turn signal switch could also be the problem. Go ahead and try a flasher is easiest quickest test. An Ideal 552 flasher will work esp as a test unit.
Good luck and welcome to the board
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
Re: what is it
thanks for the welcome and i will try this in the morning,
thanks again
Greg
thanks again
Greg
