1967 f250 flasher
herzberg
1967 f250 flasher
Post by herzberg »
I am looking for the flasher on a 1967 f250. I have the instrument panel out of the truck and cannot find the flasher.
I have no turn signals, brake lights or emergency flashers, figure it may be the flasher.hope someone can help.
thanks Greg
Re: 1967 f250 flasher
check the fuses for power going to wire 810 to the column. it should be a black wire with red stripe. http://www.fordification.com/tech/wirin ... ghts02.jpg
fireguywtc
Post by fireguywtc »
My 67 had a big box looking flasher that was mounted behind the instrument cluster just to the left of the ash tray.
Bill
1970 F-250 4x4 highboy ranger 390 V8, 4spd
2012 F-350 PSD FX4 LWB CC lariat, white
http://www.fordification.com/galleries/ ... hp?uid=602
"If you want to judge a person's true character, give them power."
herzberg
Post by herzberg »
thanks to all, I was looking for a little round flasher, this is a camper special so it has the large heavy duty flasher just left of the ashtray like you said..
thanks so much,
gonna change it and see if it works
Greg
my guess it that it is a fuse or bad wiring to in or from the steerign column. maybe the turn signal switch.
herzberg
Post by herzberg »
i will definitly know tommorrow
thanks to all
mk
Post by mk »
I'll second on the t/s switch...
and it's not because it's a camper special that it has the box flasher; they combined the regular and emergency flasher into one unit on the early production '67s built before dec 66/jan 67, I believe.
mike
~Will Rogers
Mercury truck ID thread:
Ford truck model history:
Using dentside fender liners:
Matchbox diecast bumps:
so then i would need the single square box flahser for my 67 then? if i don't have a dual flasher set up for blinkers and hazards seperatly.
fireguywtc
I put the small round flasher solenoid out of a newer truck in my 67 years ago and it ran both the blinkers and the hazards with no problems.
Bill
