CD Player Issue
t_doody
CD Player Issue
Post by t_doody »
Hello!
I recently put a new battery into my truck and wasn't paying attention to which way I had put it in, and I stupidly connected the Positive Cable to the Negative post, and something attached to my starter relay smoked and sizzled. After quickly removing the cable and hooking the battery up the RIGHT way, the only casualty so far that I can tell is the aftermarket CD player.
I checked the fuses and nothing needed to be replaced.
Anyone have any ideas?
Re: CD Player Issue
it might have ate the radio. since the power was going the other way the fuse may not have blown. mayeb the ground wire is burnt up.
t_doody
Re: CD Player Issue
Post by t_doody »
How do I find the ground wire?
Sounds like either way I am going to need a new deck?
knightfire83
Re: CD Player Issue
Post by knightfire83 »
Which fuses did you check? The ones at the trucks fuse block?
Usually there are two inline fuses behind an aftermarket radio in the wiring leading to it. I'd be sure to check those before you write off the CD player.
You would think that the aftermarket manufacturers would spend :2cents: :2cents: on a couple diodes to prevent their radios from getting smoked in such a situation.
1970 Ford F250 4x4 ~ Sold.
Re: CD Player Issue
the ground wire is usually black.
t_doody
Re: CD Player Issue
Post by t_doody »
I checked the fuses underneath on the firewall on the drivers side, I checked the fuse that's inside a plastic holder near the starter relay, I checked the 2 that were behind the deck. Those were all fine.
All the wires that are for the after market deck are red, I didn't find a black one.
I am very puzzled.
Re: CD Player Issue
it might just be a body ground type of ground too. so there may not be a wire. its possibly toast.
knightfire83
Re: CD Player Issue
:yt:
Probably Image
t_doody
Re: CD Player Issue
Post by t_doody »
awesome. so here's my next silly question. They guy I bought it from installed an mp3 jack for ipods and such. Do I NEED a working radio deck in the truck to use that? Or is the jack wired into my speakers.
Thunderfoot
Re: CD Player Issue
Post by Thunderfoot »
The radio has to work as that is the amplifier for the mp3 player to power the speakers.
t_doody
Re: CD Player Issue
Post by t_doody »
sounds like i should just spend the money and get a new deck instead of an ipod.
Thanks for the help!
PS Pics of my truck coming soon I promise.
killakobra
Re: CD Player Issue
Post by killakobra »
i almost did with my EQ yesterday. wasn't paying good enough attention to + and - and i saw smoke. thankfully it still works. it is possible that you did fry it.
1967 f100 stepside 300ci I6
1969 f100/600 stepside retro truck -under construction-
1972 longbed trailer
Re: CD Player Issue
i changed batteries in my 94 the other day. and thought i put it in right. when i hooked the cable up backwards it killed the engine.
quantumleap
Re: CD Player Issue
Post by quantumleap »
ouch.... :doh:
Daniel--67' reg cab black shortbed/fe/4spd/ford 9
Re: CD Player Issue
i swapped the cables back and the truck started right back up. no problems.
