Short list of electrical questions.
nexizen
Re: Short list of electrical questions.
Post by nexizen »
I've tested the sending unit and it's fine. (I even bought a new one.) I have also tested the wire that connects to the gauge cluster and it seems fine. (It's just a ground that runs through the sending unit....right?)
When I test the voltage at the gauge, I get the variable reading. Is that normal? If so, then it would make sense to me that the gauge is bad.
Andrew
nexizen
Post by nexizen »
Can anyone tell me what voltage range I should be seeing across my temp gauge? I'm thinking more and more that the gauge is bad.
Andrew
70_F100
Post by 70_F100 »
You should see pulsing 5V.
An analog meter works best for checking this.
