f500 cluster ?
steve59136
f500 cluster ?
Post by steve59136 »
I just bought a f500 instrument cluster off ebay and want to know if there is any reason it would not fit in my 67' f250
the ad says 68-72 but according to your section on cluster differences 67 and 68 are the same. is that true?
here is the link to the ad.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWNX%3AIT
contact me if you can help with information about my 67' f-250
flatblack
Re: f500 cluster ?
Post by flatblack »
nice find, i was watching that one myself, as for the question i have no idea, but i would imagine it will work. :)
Nitrous is like a hot girl with std's... you know you want to hit it but your afraid of the consequences
Re: f500 cluster ?
It'll work just fine. :thup:
steve59136
Re: f500 cluster ?
Thank you for the insight. As far as the vacuum gauges that came on most of these clusters (this one never had one) is there any use for it on my model truck? I figured they were used for the air brake system in the larger trucks but on mine could is be used to monitor engine vacuum and if so is there any pluses to keeping an eye on that? What are other guys putting in these clusters?
On my second 67' f250 first one was killed by a red light runner two years ago.
Re: f500 cluster ?
the vacuum gauges are for watching the engine vacuum. there are seperate gauges for air brake tank pressure.
steve59136
Re: f500 cluster ?
Thank you for the correction on the brake mistake. Do you see them come up for sale often? Just the gauge I mean and the install where does it hook up to. its just a hose right?
Re: f500 cluster ?
i havent seen only the gauge for sale veery much. maybe once. i dotn know how they hook up. probably just a hose.
mljjones67
Re: f500 cluster ?
Post by mljjones67 »
I have a vacuum gauge out of a f-600 cluster I could let go of. I wont be using it.
mljjones67
Re: f500 cluster ?
emailed ya.
you can take you email off the last post so the moderators don't have to.
mljjones67
Re: f500 cluster ?
oops to late. Thanks Keith.
mljjones67
Re: f500 cluster ?
Click for larger photo's.
$25.00 +shipping
garner67
Re: f500 cluster ?
Post by garner67 »
Dang, I've been looking for a F600 vacuum gauge. It'd be cool to have a working vacuum gauge in my panel.
Guess I'll keep on lookin.
71 F100
Mike
steve59136
Re: f500 cluster ?
Thank you for all the great input on the vacuum gauge. I am still looking for one that matches the other gauges ( just a black face with white numbers) I saw one on ebay but didn't get back on line to bid in time it went for just over $13 what a steal. Does anyone know the OD of the gauges that came in these larger trucks? I found one that looks very similar the part number is: F3HZ-17360-A the seller says its OD of the bezel surrounding the face is 3 3/4" it's not listed on the parts page of this site. It's an electronic tach and was wondering if it would be easier to use it rather than the cable driven tachs that came in the trucks. I think I even read somewhere on here that a cable driven tach can not be hooked up to our trucks since most of the trans. are not made to accommodate one. What does anyone know about that? Any info would be helpful.
