4X4X4 roof console and dakota digital dash
- zakt
Re: 4X4X4 LET THE GAMES BEGIN!
Rob,
what did you do for coating on the inner fender brackets attached to the firewall?? Im thinking there might be clearance issue if that is coated and the inner fender to get that to get in there?
1972 Ford F350 crewcab
Ryan and Todd, The coating I used is Rhino Liner. It is tintable so you can make it the exact same color as you are spraying the rest of the truck. I used this on the inner fenders, wheel wells and aprons.
As for the firewall brackets, those are painted. Only the inside part of the fender apron was coated and there was no problems with clearance.
The power port would look good in place of the ash tray, just looks cleaner and less cluttered. It was easy to fill it in too
I can't remember where I found the thread for the aux battery tray. Try a search and see if it comes up.
Waynaferd,Regarding the Frame, I took it to Redi-strip and had them dunk it for me, came out brand new clean. I also had some pitting in the sides and I just used a Primer surfacer and sprayed 3-4 good coats and sanded it smooth. I then applied an epoxy primer and then eastwoods porcelain urethane chassis black paint. Very happy with the outcome, it was a lot of work.
Just finished putting on the passenger side mouldings tonight. Here are a few pics.
Here are the B pillar mouldings
I had to cut the end piece from a pair of front fender mouldings and weld an aluminum plate on the end
I then ground down the end piece to match the "bump"
checking the fit
aligning it with the front door moulding
and then installing the fabricated rear door moulding
Tricky getting all the mouldings to line up nice. here is the rear door and B pillar mouldings
The passenger side all done. had to do the same thing to the rocker mouldings
Here is a view of the dash with the glove box installed and the double din installed. I need to have a face plate CNC'ed for the stereo face to clean things up.
Got the tool box door handle chromed and the mouldings installed. the door moulding was really a mess but the polishing shop did a great job cleaning it up.
Polished mirrors on now too
I will be working on the hood this weekend. Hopefully I can paint it next weekend.
checking the fit
anything worth doing is worth doing in EXCESS!! - Carroll Shelby
70 F-350 4X4 crew
70 F-350 4X4 crew
- fomocoguy
Very cool! Nice work on the trim. That's really sharp.
Joe
1971 F100 flareside 8ft
1964 Chrysler New Yorker Town and Country wagon
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
2005 Ford Ranger
- zakt
trim looks good, did you just spray paint the black on it?? cant wait to do mine... Im using the narrow trim vrs the wider trim you have still debating though on using the bottom trim?
- FordJW
Just discovered this thread, very nice work
Jan-Willem Adams
Adams Classic Cars
http://www.adamscc.nl
71 F100 Ranger XLT 360, 66 Mustang 289, 54 Packard Patrician Exec. Sedan
Adams Classic Cars
I'll hafta find some of that "elbow-grease" stuff to get mine clean...there's no places like that around here to dunk it.rattlecan wrote: Waynaferd,Regarding the Frame, I took it to Redi-strip and had them dunk it for me, came out brand new clean. I also had some pitting in the sides and I just used a Primer surfacer and sprayed 3-4 good coats and sanded it smooth. I then applied an epoxy primer and then eastwoods porcelain urethane chassis black paint. Very happy with the outcome, it was a lot of work.
Anyway, thanks for the info how you did it!! I'd like to get mine smooth enough to spray some glossy glossy color onto. We shall see how that turns out
A 72 F-250 Hi-Boy "project" ( that means sitting untouched for 3 or so years)
And a little 94 F-150 Flareside, 7" higher and 35's...
- Eric L
rattlecan, I'd like to pick your brain on the frame stretch.. My plan is to use my 67 CC frame with the front half of a 72 F-250 4x4 frame. prelim measurements say I will make the cuts under the rear floor on the CC and behind the divorced transfer case on the 4x4 (I think..it's been a while since I was under there). The cutting and welding is no prob for me, but I'm questioning the elevations of my cab/rad support mounts on both trucks, especially the 4x4.. there are a lot of shims under the core support and she's not been treated kindly over the years. where did you get the dimensions to build your frame? I thought about duplicating the CC dimensions, but it would be nice if there was some reference material to check against.
Thanks, Eric
just for fun here's pics of both trucks
Thanks, Eric
- 69FLATBED
I had forgetten about this project,Man, that thing looks great!!
Troy
_________________________
2000 F350 4x4 Crew Cab PSD
1969 F350 Flatbed 360 4spd DRW
!968 F250 4x4 Crew Cab SWB
Love my diesels hope to be gasoline free soon!
You might look here at the factory drawings, they might help some. http://www.fordification.com/tech/bodybuilder70.htmEric L wrote:rattlecan, I'd like to pick your brain on the frame stretch.. My plan is to use my 67 CC frame with the front half of a 72 F-250 4x4 frame. prelim measurements say I will make the cuts under the rear floor on the CC and behind the divorced transfer case on the 4x4 (I think..it's been a while since I was under there). The cutting and welding is no prob for me, but I'm questioning the elevations of my cab/rad support mounts on both trucks, especially the 4x4.. there are a lot of shims under the core support and she's not been treated kindly over the years. where did you get the dimensions to build your frame? I thought about duplicating the CC dimensions, but it would be nice if there was some reference material to check against.
Thanks, Eric
- papabug71
rattlecan, very nice work on that trim. I love good clean custom work
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
Hey everyone,
It has been awhile and work has been slow. I have been working on my dads 58 ford fairlane, he needed my help with getting it finished for the car show in august. I will post some pics of that In a few days, it is a really neat car.
But I wanted to let everyone know that my truck will not be done for Hot August Nights. I will, however have it at Knotts Berry ford show this coming april.
I also have more pics of my new seats that I will post as well.
Rob
Rob
70 F-350 4X4 crew
70 F-350 4X4 crew
It's cool that you held up your project to help your Dad. Dad's are great.
55F100
55F100
Do you have any updates on your truck?
- FormerMarine1981
Awesome build. You have put a lot of detail into your truck. Want to do mine next???
Awesome build... Keep up the posting...
302 3 speed
(converting to automatic)
302 3 speed
