NO Right brake, or emergency flasher light????
customcamper
Post by customcamper »
He guys....I have a 70 f250 and I dont have the right brake light or emergency flasher, but I do have the right blinker & right marker. any Idea what color the wire is (brown?) for the right lights and any troulbe shooting tips??? Thanks, Dave
Re: NO Right brake, or emergency flasher light????
brown is tail lights. it is either yellow or green i cant ever remember which is for which side. check for power going into the flasher and or coming out. if it is coming in and going out the switch is good. if it comes in but doesnt go out thent he swithc is bad. if no power gets to the flasher switch the fuse or wiring is bad. it could also be a bad bulb on the right side.
Thunderfoot
Post by Thunderfoot »
That is the a (Turn Signal Switch) problem, the contact inside it for the right brake light is bad. The brake light and E-flasher are the same wire going into the TSS and then it separates the power to the right and left side. You might be able to fix it by just replacing the TSS Cam... :2cents:
