blinker
pltmgr
blinker
Post by pltmgr »
68 f100.I replaced the canceling cam and now only my right front and left rear blinker work. bulbs are good and everything worked before I started. ?? thanks
pltmgr
Re: blinker
Post by pltmgr »
found the problem. The new canceling cam spring was not making contact inside the tss. Merely bent the spring out and the problem was solved.
