Bouncing Speedometer?
- alvald83
I have a bouncing speedometer that is driving me crazy! Is this a lubrication thing?
- alvald83
Re: Bouncing Speedometer?
Do i just add some type of lubricant into the speedo cable at the gauge cluster?
- mlheppl
Remove the cable from the truck. Run some penetrating oil through the sleeve and clean out as much grime as you can. Then re-install the cable after cleaning and lubricating it. FME once the bouncing starts, the cable doesn't last much longer. Others may have had better luck. If the cable is damaged, you can get a replacement at the local auto parts store. I believe I paid around $8.00 at napa for the last one I bought.
Mike
71 F250 4X4
99 F250SD 4X4 7.3L PSD
71 F250 4X4
- alvald83
good idea.
- 70_F100
What transmission do you have?
That's not an oil leak
- alvald83
I have a C6
- 70_F100
PM sent
- fordamericana
I was always told never put any kind of liquid anything into the speedometer cable, to only use graphite...
I likes My FE I does...
- AK F100
fordamericana wrote:I was always told never put any kind of liquid anything into the speedometer cable, to only use graphite...
That's what I have been told also.
GPBFD Pyro Maniac
Daily Driver: 1974 F100 4x4 (ride'n on 8-Luggers) Build in progress
1997 F-350 Crew Cab 4x4, 7.3L Diesel SOLD
Pile-O-Parts: 1968 F100 - 2WD Shorty SOLD
Looking for a new project 57-60 Ford Truck
- 70_F100
I've used Lubriplate 105 for the last 40 years or so, and most of that was on heavy-duty trucks that go millions of miles.
It's always worked fantastic for me in the past, and I still continue to use it.
Pull the core out of the housing and grease it up well as you reinsert it.
- vlrd56
it is I thinck a nonsense to poor graphic in something allready dusty or rusty ,it fills more object in it.WD 40 or locks lubricant which are not too greasy must do
http://photobucket.com/vlrd56
Chrysler 300C
Fiat panda(wife's car)
Alfa Romeo spider 1981
jeep Delahaye 1956
Yamaha XV1000 se 1984
Bultaco Sherpa 350 1980
F250 XLT 1991 shame on me
Same corsaro tractor 4WD 1974
Chrysler 300C
jeep Delahaye 1956
Buy DC speedocable for $20 and your finish with problem. My came fully lubed, I added some just to be sure. I had bought one from LMC, a piece of crap, broke after only a few miles, changed inner cable, added lube and it still bounced like crazy.
- 70_F100
I bought a DC cable for mine when I did the tranny swap, and it had no lube on the core at all...cajuncannon03 wrote:Buy DC speedocable for $20 and your finish with problem. My came fully lubed, I added some just to be sure. I had bought one from LMC, a piece of crap, broke after only a few miles, changed inner cable, added lube and it still bounced like crazy.
from what i have been told. the new cables originally didnt have any grease in them. because the grease over the years could get hard and make the speedo cable freeze up. graphite is a dry slick power that lubes without a liquid to get hard and freeze up is why it is used . if you have dust and rust inside of the cable grease may work for awhile.
