Interior Switch Identification
Skitzo
Post by Skitzo »
My buddy has a 71 and I have a 72 and we can't for the life of us figure out what the hell these switches and/or lights are on the drivers side. I'm sure you guys can clue us in and I hope I don't feel dumb when I find out, lol.
Thanks much
69rangerf100
Re: Interior Switch Identification
Post by 69rangerf100 »
the one on the lower dash is the brake light and the other is a safety light
David
Dream as if you'll live forever, live as if you'll die today - James Dean
Daily Driver - 1998 Honda Accord
Wife's Ride - 2007 Ford Explorer Sport Trac
Project - My Dad's 1969 F100 Ranger 390 w/ 3spd manual coming soon PS, PB, A/C and alot of paint and body work - Miss you Dad
http://s936.photobucket.com/albums/ad208/69rangerf100/
BobbyFord
Post by BobbyFord »
The one in the door jamb is the ambient sensor for the TRS system.
69rangerf100
dumb question what is the TRS system i have never heard of that
David
BobbyFord
Post by BobbyFord »
Transmission Regulated Spark control. http://www.fordification.com/tech/image ... /trs04.jpg
Skitzo
Post by Skitzo »
Brake light? Is that a low brake warning light or something? Wow, so weird I was just looking at the TRS system wondering what the hell it was. Killed two birds with one stone on that one, but I have a question about the TRS system (thread steer). Is the vacuum line going to the carb from that part #12A170 constant or does it go to the timed port? As of now on mine it's to the timed port on my truck and that doesn't seem right. I'm going to slap on a new BG Demon Jr. carb to it and I'm wondering about that vacuum line. Thanks guys, this forum is so much help!
the brake warnign light is for a brake fluid imbalnce in the brake fluid system. if the brakes ever go low in either the front or the rear the brake block will trip to one side. and the system will be imbablanced. so the light will come on to tell you the fluid is imbalanced.
sargentrs
Post by sargentrs »
fordman wrote:the brake warnign light is for a brake fluid imbalnce in the brake fluid system. if the brakes ever go low in either the front or the rear the brake block will trip to one side. and the system will be imbablanced. so the light will come on to tell you the fluid is imbalanced.
Please forgive the hijack but, how is that triggered? The PO of my truck put a toggle switch in that hole for some reason I have yet to figure out. Nothing's hooked up to it. I always thought he drilled it in there for fog lights or something. It would be nice to hook it up for it's original use. What kind of switch actuates it? Thanks!
We now return you to your previously scheduled programming......... :oops:
70_F100
Post by 70_F100 »
There's a switch in the distribution block that trips when the pressure drops in either the front or rear brakes (split system).
seattle67
Post by seattle67 »
On the frame of the truck, below the master cylinder, is a brake fluid distribution block. It has a differential pressure switch in it that senses a difference in pressure between the front and rear brakes. So if you lose brake pressure, say in the front brakes, it will activate the switch. The switch then sends a ground signal to the lamp on the dash and voilà, you have a light.
sargentrs
Post by sargentrs »
Cool. Thanks guys! I'll checkthat out. :fr:
