STICKY: Best mods or upgrades you have done to your bump?
No tech discussion, please
austin
Re: STICKY: Best mods or upgrades you have done to your bump?
Post by austin »
to date the best upgrade has to be p/s hands down
ccryder2011
Post by ccryder2011 »
its more of a repair than an upgrade but i would have to say headlights and adjusters....now i can see... :woohoo:
remember the key is to start what you finish....lol....happy cruising...
1967 f-100 sb,mine
2007 subararu wrx,son#1
2003 mitsubishi eclipse,son#2
2007 mercedes E 350,wifes
basketcase0302
Post by basketcase0302 »
nuts-n-bolts
Post by nuts-n-bolts »
i just put a 67 swb bump on a 1988 f350 4x4 5 speed 7.3 diesel
and love it
ccryder2011
nuts-n-bolts wrote:i just put a 67 swb bump on a 1988 f350 4x4 5 speed 7.3 diesel
and love it
pics please....
1967 f-100 sb,mine
austin
Post by austin »
and love it
pics please....
+2
71highboy
Post by 71highboy »
remove the dashpad filled in all the holes and painted i think they look better without the dashpad.
cozadlance2
Post by cozadlance2 »
The exhaust. 2.5 inch dual to muffler in front of back axle then 3.0 inch single pipe over axle and out passenger side behind tire. So far I have loved all the changes but that is the nicest so far.
I am an outspoken person. I will not be quiet to make you happy.
robwymer
Post by robwymer »
Best upgrade - new 300 six engine.
Most beneficial and easiest upgrade - new bench seat from back of 1994 crew-cab.
67 F-100 Flareside, 300, Offenhauser 360, Holley 390, Duraspark and MSD ignition, NP-435 4-speed, 3.55 Dana 60, and it will absolutely roast 30" rear tires taking off in 2nd (the one time I tried scared the Bejeezus out of me)
Next engine mod: RV cam (252*)
"They just don't make 'em like they used to."
jp2005
Post by jp2005 »
I would say my aluminum pulleys so far! What a difference!
Thanks JP! Ms. Cordova is a factory 1969 Ford F100 Ranger with a 390, Front disc brakes, Cordova copper orange, behind the seat box
Whateverman
Post by Whateverman »
disc brake conversion
robwymer
Post by robwymer »
Did another great upgrade this weekend - replaced all the lock cylinders so that I can lock and unlock both doors from outside again, and the doors match the ignition, all for around $40!
Here's what I did:
I bought the set off e-bay for about $40. There is at least one for sale right now for $40-$50 shipped, item #350438201964.
One note on installation: The door locks came as pictured with a flat armature which had a circle in it. I had to clean up the armature on my old locks and install them on the new lock cylinders, a very simple and rewarding process.
Additionally, replacing the ignition cylinder was very simple.
1. Disconnect the battery ground cable.
2. Insert your key in your old ignition cylinder and turn to accessory position.
3. Insert scratch awl tip or something sharp and hard into small dot on face of ignition cylinder and simultaneously turn key to left. I had to sharpen the tip of an awl with my grinder.
4. Remove old cylinder.
5. Place new key in new cylinder, turn to accessory.
6. Place key and cylinder into ignition switch.
7. Use scratch awl to push small dot on new cylinder, simultaneously turning key to left.
8. Finish pushing cylinder into switch.
9. Reconnect battery, driver her around, and lock the doors when you're done - without having to fish around for another key!
Rob
Voodoo67
Post by Voodoo67 »
Hmm that's an easy one.. the best mod so far has been the WS6 clip with disc and power steering, second would be the steel tilt front end I made for it, I can sit on my tires and work on it comfortably......heck that's worth the price of admission.....
hazelnut
Post by hazelnut »
Best upgrade was replaceing the rusted out cab and bed with another cab and bed without rust.
jp2005
Post by jp2005 »
Getting A/C charged, for the 100 degree weather coming.
