1971 f100 360 2wd (2-piece drive shaft)
I'd like to replace the U-joints one of these weekends, and thought I'd better replace the center support bearing also.
Any hints on how to do this? Does it just drop down and slide off?
Center support bearing
re: Center support bearing
Most auto parts stores have the press to r&r the carrier bearings. Good idea to at least check and if at all questionable replace. They can leave you stranded!!
69 F100 300I6
67 Mustang fb FE 431ci
72 Gran Torino Sport 351W
91 Bronco 351
69 F100 300I6
91 Bronco 351
I got mine pressed off and the new one pressed on at a driveline shop. Think it was about $25.
