auto shifter
71 side step crazy
auto shifter
Post by 71 side step crazy »
How do I remove the knob on my auto shift trying to put a new one on
Re: auto shifter
its a press fit.
71 side step crazy
Re: auto shifter
So dose that mean it won't come off
Re: auto shifter
they will come off. i just dont know the best way to do it.
thorn1968
Re: auto shifter
Post by thorn1968 »
Grab it with a vice-grip and twist. :evil:
Re: auto shifter
they are splined. the only way i would approach it is to use a pair of pliers and pull like crazy or mash it into pieces.
Racer Z
Re: auto shifter
Post by Racer Z »
With or without splines, grabbing something like that with pliers is the best way to ruin it.
How it comes apart I don't know.
If it was pressed, it needs to be pressed off. That means you need a press and the ability to make a holder. Probably a two-piece holder.
ta TACO
Re: auto shifter
Post by ta TACO »
I just did this. I took a cresent wrech and got it as tight as I could around the shift arm, butted against the handle and tapped the wrech with a hammer. Hope this makes sense, but it worked and didn't damage the handle.
68 F-250 CS, 360 or 390?, still haven't measured the stroke, AUTO running on propane!
Racer Z
Re: auto shifter
Post by Racer Z »
Just as long as you don't use a screwdriver as a pry-bar it's OK. LOL Good job. :)
BobbyFord
Re: auto shifter
Post by BobbyFord »
Put a slice in the side with a cut-off wheel and spread the slice with a chisle.
