windsheild wipers
windsheild wipers
working on the restore and can't seem to get the wipers off from the cab? Any thoughts. Thanks
1967 F-250
Re: windsheild wipers
they pull right off. they are probably rusty or corroded. . what i do is to pick up on the arm. then on the end of it. opposite the arm. i pry up with a screwdriver. if the cab has been painted and want to save the surface put arag under the srewdriver tip. or where ever you pry against the cab.
Is there a little tab under the bottom to pull out? Been a while since I did mine and I've done a lot of other vehicles since then.
i think there is. the ones i pulled off sunday came off in the way i described above. so yours may be catching on that tab instead of rust.
I believe they are caught on the tab. I'll try to post a pick later today.
1967 F-250
if it is caught on the tab use two screwdrivers to pry it off with. once it starts to come up past the tab then you just need one screwdriver to pry with
Here is the link for the Pics http://s1184.photobucket.com/albums/z32 ... t%20three/ First Pic is of the whole thing. The second Pic is looking down at the wipers. just to clarify the tabs are where? Just to make sure I don't brake any thing. Thanks for the info
1967 F-250
thanks for the info. I won't be able to get to them until next wed at the earlist. I'll let everyone know how it goes. Thanks,
1967 F-250
