will this carpet fit?
nolan in blaine
Post by nolan in blaine »
http://bellingham.craigslist.org/pts/2305002772.html
I have a 70. I thought the floor plan changed in 73. Should i get it or look deeper into it first?
nolan in blaine
Re: will this carpet fit?
not enough information. the floors pans and hump cover are the same in our trucks. but the 73 and up arent exactly the same floor area. i tmay not fit. it may just hang out the doors a slight bit. ask the guy what truck he was going to put it in before you tell him what truck you have.
nolan in blaine
ok i will makes sense thanks guy
nolan in blaine
mk
Post by mk »
You should have no troubles with the 73-79 carpet as long as the trans hump is the same height as what you have. I've got a '79 Lariat carpet in my '68 and just had to shorten up the rear edge and a little bit where it goes under the firewall cover.
mike
~Will Rogers
Mercury truck ID thread:
Ford truck model history:
Using dentside fender liners:
Matchbox diecast bumps:
