need to dye some seat belts
70 ranger
Re: need to dye some seat belts
Post by 70 ranger »
Dupont Vynle dye. This stuff is great. I used it on a dirt bike seat to see how tough it really is and let me tell you it is tough. Since then I have used it on many different interior parts. I switched to Sikken a few years ago and have been using Sikkens water borne with a modifier agent that is meant for under hood colors. That is what is in my truck right now. It looks good but I haven't used it to much yet to tell you how it lasts. If you are interested check it out at automotive sales (paint supply store) in Courtney. The guy that works there is Eldon. If you need any more info PM me.
1970 ranger 4x4
1965 mustang needs resto
flh shovelhead
rigid evo
Whateverman
Post by Whateverman »
thanx,i'll hafta check it out
Hawkrod
Post by Hawkrod »
You won't have any success dying belts and if you do, throw the belts away because they are no good! Seat belts are made from materials that are not easily affected by things such as dyes because if they were they would degrade and fail. Most belts are made from materials that are not dyed, the material they use to weave the belts has the color in it. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
Whateverman
i ain't chuckin em,took me too long to find the suckers in the first place,there's nothing wrong with em (except the brilliant blue finish),and i don't want to waste $$ on getting a new set if i can make em do what i want
i'd rather spend the $ and time sorting out the real issues my truck has
70ford1
Post by 70ford1 »
Check out this site--www.lmctruck.com and check part #42-0750--ColorBond---new & seems to be the ticket--
Good luck.
