Stock RPM swap?
hotrod ford
Stock RPM swap?
Post by hotrod ford »
I have a stock RPM gauge for a F600 cluster. It has the port that would connect to a mechanical distr. It will not work on my elec. distr. So, could I gut it and replace the enternals with an after market RPM gauge so it will match my speedo and vacumn gauge in my stock F600 cluster?
Mancar1
Re: Stock RPM swap?
Post by Mancar1 »
If you mean can you take it out and replace it with one that will work for you. Sure if you find one that fits and you like the looks of it. Your speedo, tach., and vac gage all run off different sources.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
hotrod ford
Re: Stock RPM swap?
Mancar1, what I want to do is keep the casing of the stock rpm and replace the enternals so the face looks stock the same as the others. I understand that they work off of different systems, so thats no issue.
michael69
Re: Stock RPM swap?
Post by michael69 »
Not that this is any help but I remember someone doing that very thing a few years back but don't know who it was. It should not be to hard. If you want to just get a new tach that matches I found that the factory tach in my CJ 7 jeep matches the f600 gauges pretty darn close. If you want to look at them there are usually some on ebay. Just a thought.
Michael69
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
hotrod ford
Re: Stock RPM swap?
Thanks Calfdemon, that will surley be an option that I will think about. At least I know now that it will be able to do. :thup:
Mancar1
Re: Stock RPM swap?
Post by Mancar1 »
hotrod ford wrote:Mancar1, what I want to do is keep the casing of the stock rpm and replace the enternals so the face looks stock the same as the others. I understand that they work off of different systems, so thats no issue.
Ok thanks for clearing that up in my old brain :lol: Yes I agree what you want to do is a can do. Just takes patience, but you can do it.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
