Hey guys..
I'd like a little advice/experience on this one..I have a 68F100 Ranger and I need to remove the door panels to grease window tracks and fix a lock mechanism..
Im looking at the door panel and I know how the arm rest and window crank are removed, but what about the trim around the edge of the door panel? Does it pop off? or is it held with a screw of some kind? Or is it integral?
Anyone with previous exp, I appreciate the help.
Thanks!
289kman
68 F100 door panel removal
Re: 68 F100 door panel removal
the trim usually pops off. my 68 is the only one i have seen that has screws through it. probably becasue it had the plastic coverings over the door panels at one time. before i removed them. i think i thas 4-8 screws holding the trim from the outside. otherwise yours probabl pops off. it is held in by wedged types of clips into the door panel. the snap into the trim and then push into the door panel holes.
Thanks all..! Your tips made this easy... job done!
