1967 F-100 project
goldies67
Re: 1967 F-100 project
Post by goldies67 »
id go with the efi unit! more dependable and durable! its a hassle to graft the harnesses into it,just take EVERYTHING of the donor truck before you scrap it! good looking build you got there! :thup:
1967 f100 styleside
67nukeford
Post by 67nukeford »
I'm going to grab as much of it as I can, just in case I do. Otherwise, I'll run a carb for a while, then get an aftermarket EFI setup.
Pat 1967 F100 4WD
LINK TO PROJECT THREAD
:http://www.fordification.com/forum/view ... &sk=t&sd=a
67nukeford
Got the cab home yesterday, and on the dolly. I'm going to have to fabricate the panels on the inside of the cab corners, since I don't think those are repopped. Probably sand blast the bottom, to see what needs what.
Pat 1967 F100 4WD
fbomb100
Post by fbomb100 »
moving along slow but sure... looking good
marvin2
Post by marvin2 »
I'm sure that dolly comes in handy....I'll may think of doing something similar for mine. I think keeping the efi from the donor truck would be really cool.
1970 F100 "Marvin 2" - Crown Vic IFS, 302, C4 (work in progress)
1970 F250 "Leonard" - 302, C6 (project in waiting)
1971 F100 "Walt" - 302, 3-speed on the column (Sunday driver)
2004 Mustang GT "Horse With No Name" - 4.6L, 5 speed (Retired daily driver / Friday driver)
67nukeford
The dolly works great. Big thing was making sure I got casters big enough to handle the weight. Makes it easy to move this thing around!
Pat 1967 F100 4WD
67nukeford
Got the motor and tranny out of the 89. Amazing how clean the backside of the motor was. And, check out the differnce in transfer cases in the last pic. That little thing at the bottom left is the original out of the 67, next to the one out of the 89!
Pat 1967 F100 4WD
Fordnatic
Post by Fordnatic »
Coming right along!
55F100
67nukeford
Before and after pics, got the bottom of the cab sandblasted. Floor is really solid.
Pat 1967 F100 4WD
67nukeford
I will have to replace some metal in some spots, like this corner, and on the floor support channel.
Pat 1967 F100 4WD
67nukeford
Started working on the spot welds on the front cab mounts. I bought the two bit set from Eastwood, comes with a 3/8 and 1/2 spot weld cutters. Works really well, using WD-40 to keep the bit cool.
Pat 1967 F100 4WD
67nukeford
The passenger side is rotted pretty bad on the outside. Plus, I want to clean up the floorpan beneath them, so might as well install new mounts. The mounts I got from NPD are essentially the same as the ones DC offer, but they are way less expensive. I plan on cleaning up the floorboard beneath then, and then put on POR-15 under, exept where they will be spot welded back on. I'll put weld through primer there.
Pat 1967 F100 4WD
67nukeford
Here is why I'm pulling the front cab mounts. Pulled the passenger side last night, it's pretty roted out, as you can see in the first pic. And, I want to clean up that rust underneath, and seal it all up.
Pat 1967 F100 4WD
67nukeford
Here is another shot of that mount. It's not in good shape.
Pat 1967 F100 4WD
tylerb43
Post by tylerb43 »
Oh wow, that's so much worse than it looked in the previous photos. I really didn't mean for it to sound like I was telling you what to do, I was simple commenting on what I saw. Just trying to return some of the help and opinions I've been given, sorry if it came out wrong.
On the up side, those floors look solid, right? And I can't wait to see how you patch those inner rear corners, as I'll be doing mine soon too.
Absolutely awesome job so far buddy, keep it up - I can't wait to see the updates! :thup:
:fr:
