Bouncy Needle
JL100
Bouncy Needle
Post by JL100 »
I didn't want to "hi-jack" another thread, so forgive me if this is somewhat repetitive sounding. My speedometer needle on my '67 F100 is extremely "bouncy." The only time it stays somewhat still is at a good cruising speed. I haven't taken apart the dash just yet since purchasing the truck, but was wondering if anyone knew of the fix for this? I read on another thread about a gear of some sort, and am assuming that could be the issue...but my Dad always told me that when I assume it just makes an "A** of U & ME", so I'm gonna ask you guys. :lol: Thanks as usual!
1967 Ford F100
4th Owner
300 I-6
Front Disc Brakes
CrypticRacer13
Re: Bouncy Needle
Post by CrypticRacer13 »
JL100 wrote:...but my Dad always told me that when I assume it just makes an "A** of U & ME", so I'm gonna ask you guys. :lol: Thanks as usual!
A guy at work says the same thing :lol: :lol: to funny
Anyways my truck does the same thing at anything under 25 it seams :pop:
-Mike-
ECV 1849
Build>http://fordification.com/forum/viewtopi ... 22&t=68225
69' F250 Highboy 390ci.,NP435,Dana 24,HPD44,D60
67' Dodge Coronet R/T 440ci.4speed,D60, all numbers correct
72' Dodge Dart 440ci.727,D60,10ptcage street strip on meth 10.40s
05' Chevy Tahoe LT loaded for the wife an the baby duty
12' Ford Focus Titanium Hatch Back, Gas saver for the work week
Mancar1
Re: Bouncy Needle
Post by Mancar1 »
Try lubing the cable 1st. If that isn't it check the speedo gear.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
JL100
Re: Bouncy Needle
Post by JL100 »
Thanks for the input guys, I'll try checking on the gear this weekend when I get some time and I'll post back my results. I know a lot of these old trucks have this issue, but the needle on mine is just a little too active to be working right.
1967 Ford F100
4th Owner
300 I-6
Front Disc Brakes
sublimer
Re: Bouncy Needle
Post by sublimer »
I'll be interested in the results of this thread. I have the same issue.
1968 Ford F-100
240cid (3.9L) Inline 6
3-speed on the Floor
2-tone Blacks & White
Custom Homemade Headliner
Moveable Speakers
cdeal28078
Re: Bouncy Needle
Post by cdeal28078 »
Most of the time the cable and sheath just need some lubrication. It binds up and releases, binds up and releases making it jump. You can pull the cable from the tranny and speedometer, pull the cable out of the sheath and grease it up good after a good cleaning. If that doesn't fix it then it would be the speedometer head in the dash.
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
Joshpow
Re: Bouncy Needle
Post by Joshpow »
I would lube cable and try that. Under 25 mine is jumpy and the gear is good and the cable is new. Not horrible but jumps. Old one jumped all the time. Ended up having kink in housing. New cable and better but not 100%
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
Aussie_1970
Re: Bouncy Needle
Post by Aussie_1970 »
I had the same issue - where the speedo cable screws into the back of the instrument cluster was loose...like really loose..Tightened it up by hand and the problem went away...I thought that was odd but it worked
Joshpow
Re: Bouncy Needle
Post by Joshpow »
Makes sense Aussie_1970. If it got slack there itd not be real stable. Cool idea to mention.
Josh
71 F-100 Custom SWB
02 F-250 Stroke
CrypticRacer13
Re: Bouncy Needle
What type of grease should we put on the cable?
-Mike-
ECV 1849
Whateverman
Re: Bouncy Needle
Post by Whateverman »
i just use plain ol' wheel bearing grease
70_F100
Re: Bouncy Needle
Post by 70_F100 »
I use Lubriplate 105 on speedo cables.
Thick enough to stay on the core, thin enough that it won't cause the cable to bind.
CrypticRacer13
Re: Bouncy Needle
Cool thanks fellas
-Mike-
ECV 1849
mjhaltom
Re: Bouncy Needle
Post by mjhaltom »
Mine jumps too. I swapped from 3.03 3 speed to a t18 4 speed and used the same gear on the end of the cable. Didn't bounce before, does now. So I am almost certain the gear is not completely compatible.
1989 Ford F150
1966 International Scout 800
1953 Chevrolet Tin Woody
JL100
Re: Bouncy Needle
Post by JL100 »
Just to post up an update. I took out the gauge console and tightened the nut around the speedo cable. Very hard job due to the shortness of the speedo cable running to the back. After tightening (no lubing because I had not bought any) the speedometer hardly jumps at all, BIG improvement! Thanks for the advice everyone.
1967 Ford F100
4th Owner
300 I-6
Front Disc Brakes
