I have used 2 products to remove hard water stains on windows and mirrors. If not too stubborn, you can try the CLR product. It is a liquid that will remove stains from calcium, lime, rust, etc. I have also used this product on rust spots on floors, linoluem, etc. If the water is stain is really stubborn, use the Xspot water stain remover. It is a dry powder that you sprinkle onto one of those scrubbing cloths/pads with some water to make a paste. Lightly scour the stain and they should come right out. Don't scrub too hard or you might leave some scratches on your glass. BTW, they also work well on shower doors, etc. I think you can buy it at HomeDepot.
Good luck!
hard water spot removal
Re: hard water spot removal
'72 F250,390,C6,76K Sport Custom, Camper Special "Ole Blu"
'90 F250,460,48K XLT Lariat, Supercab
'88 Lincoln Mark VII LSC, 5.0 H.O.original, was daily driver, now retired
'97 Lincoln Town Car-Cartier,73K, 4.6, fact. dual exhaust,mint/original-Last Big Towncar
'05 GMC Denali XL,6.0 Vortec-for the wife & kids
'02 Cadillac DHS,4.6 Northstar-daily driver
'73 Great Divide 22' travel trailer,restored to original
'79 Mitchell 11' "Challenger XL" cabover camper-restored to original
'88 Lance 11'3" LC 780 cabover-current project
Or just try either a baking Soda mix with just enough water to make a paste or some sort or toothpaste. Just try to keep the abrasiveness down so it doesn't haze your widows. I bought a $2 bottle of window haze remover from a truck stop years ago that did a great job of hiding the rain spots until the next time you washed the windows. Normal paste wax will help hide the spots for a little while. Problem is most of the water spots are etched into the glass. You can hide them but will never remove them completely
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- 70_F100
cdeal28078 wrote: Problem is most of the water spots are etched into the glass. You can hide them but will never remove them completely
clint
It's called acid rain, unfortunately...
That's not an oil leak
That's SWEAT from all that HORSEPOWER!!
I would take even odds that if you clean the windows a couple of times with a good window cleaner that the spots will mostly come back. I have used several things over the years that made the spots disappear only to have them come right back after cleaning the windows. I hope your are gone though
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- Earthling789
The metal cleaner pastes (depending on ingredients) would provide an excellent abrasive to "dig out" the stain. If it says "not safe for chrome", then it probably has aluminum as the "grit" along with any one of dozens of acid or alkaline components. Bottom line, the metal cleaner works by abrading the stain out of the micro-scratches in the glass. I'm glad the one you used did the trick for cleaning your glass so well.
The Rain-X has inorganic silicon as the "active" ingredient (along with a methyl-compound) to "seal" the imperfections of your glass, thus providing a lower-surface tension of the glass. This low surface tension is what causes things with high surface tension (like water) to bead-up and repel so easily.
So... long chemistry lesson short... paste grinds out the stain, Rain-X seals it, but like everyone has said... it probably won't last long as the Rain-X degrades.
For a more permanent sealant, you might want to consider a higher-end or professional glass polish/sealant. I haven't used any of these in years and wouldn't dare try to recommend one, but I would have to say there are dozens of them on the market that have a nano-polymer base that are simple, wipe-on, wipe-off process and should last for many, many months before you need to re-apply.
Let us know what sealant you ultimately use, and how well it works... I'd say a lot of us could use a suggestion for sealing our freshly abraded 40-ish yr-old glass!
1969 F250 Ranger, 360 w/ 4-speed (current)
Past -
1984 F150 Flat-bed, 300 Automatic
1978 F100 Explorer, 302 Automatic
1973 F100 Custom, 360 Automatic
1969 F100 Base, 240 w/3-speed
Past -
- Swegner99
At the dealership here the lot porters use a soft steel wool and straight ammonia, just make sure you dont breath too much of that ammonia!
1972 F250 Custom LWB
1999 F150 Ext Cab
2001 E350 15 Passenger Van
1999 F150 Ext Cab
- BobbyFord
Corn starch will work also. My dad used it on his black 67 Fastback.
