glass yellowed
glass yellowed
any ideas on how to clean plexi-glass on the instrument panel it,s yellowed thanks
- michael69
Re: glass yellowed
I tried plastic polish,headlight restorer,tooth paste,compound,and everything else people say will take yellowing off. I saw a very small improvement but not enough for all the time I wasted. Spend $24.00 at one of the parts venders or on ebay and just get a new one. Thats what I finally done.
Michael69
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
Re: glass yellowed
Dennis Carpenter has them new for $25joe hermanek wrote:any ideas on how to clean plexi-glass on the instrument panel it,s yellowed thanks
- Mancar1
Re: glass yellowed
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Re: glass yellowed
I looked and couldnt find them for the 1970. It is a MUST to have this replaced as we cannot see the dash cluster at all it is so yellowed.
Also, I need the arm rests that go on the doors, but couldnt find them either. I need them in black or dark red.
Thanks,
JP
Thanks,
JP
- Earthling789
Re: glass yellowed
I've used the 3M headlight restore kits to take the yellow and scratches out of plastics before. You basically use fine grit sandpaper to remove the oxidation layer from the plastic/lexan and then use the plastic filler/polish to fill in the scratches you made and make it "shine". It works fairly well (restores to >75% new), but the kits are $18-25, which is the same as buying a new lens.... If you had an old restore kit lying around (left overs from restoring modern headlights), a little elbow-grease and time would save you from buying a new one, at least for now...
1969 F250 Ranger, 360 w/ 4-speed (current)
Past -
1984 F150 Flat-bed, 300 Automatic
1978 F100 Explorer, 302 Automatic
1973 F100 Custom, 360 Automatic
1969 F100 Base, 240 w/3-speed
Past -
- 70_F100
Re: glass yellowed
As previously posted, DC has the lens, P/N C7TZ-10880-B, cost $25. There's also an ebay seller named littleking who has (probably) the exact same part, and you may be able to save a little shipping (DC's shipping and handling charges are a little high...).d4klutz wrote:I looked and couldnt find them for the 1970. It is a MUST to have this replaced as we cannot see the dash cluster at all it is so yellowed.
Thanks,
JP
For the arm rests, the repops I've seen are JUNK!! Try ebay for some NOS ones (that's where I found mine) or good used ones. IIRC, they are the same in some later model Econoline vans.
That's not an oil leak
That's SWEAT from all that HORSEPOWER!!
Re: glass yellowed
The lens (and the part number for it) is the same for all '67-'72 F100-F350trucks, except the F350 cowl and cowl/windshield body styles, since they had a completely different instrument panel.
Re: glass yellowed
I agree completely about the re popped arm rests. Find some good old ones. Look in the mid 70's vans also as that is where I got my last one. I got one from D.C. and with in a couple of months it was cracked and about to fall off.
Clint
Clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
