Someone with an original windshield and mirror, please
My427stang
Post by My427stang »
Would you measure how far down your mirror is on the windshield? I'd like to try to put mine in the same place as stock
Thanks in advance
flyboy2610
Re: Someone with an original windshield and mirror, please
Post by flyboy2610 »
I would, but Frodo is still in the shop.
basketcase0302
Post by basketcase0302 »
The bracket on my 71' is the type that mounts onto the metal above the windshield. Don't know if it's original or not? I do know I've seen and heard of several guys here that have the same type mount, (not the newer type as you're referring to).
Sorry I can't help with the measurement. :(
Mancar1
Post by Mancar1 »
Mine is 2 and 3/4" down from the bottom of the gasket. 68 CS.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
My427stang
Thanks Mancar1
Mancar1
Post by Mancar1 »
Your welcome, and that is to the top of the mounting bracket.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
cdeal28078
Post by cdeal28078 »
basketcase0302 wrote:The bracket on my 71' is the type that mounts onto the metal above the windshield. Don't know if it's original or not? I do know I've seen and heard of several guys here that have the same type mount, (not the newer type as you're referring to).
That is not original to a 71. I know that much. Not sure what year it is original though. I'd look at my truck but I've had at least two windshields in mine since my dad gave it to me in around 79-80. lol
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
max_alberta
Post by max_alberta »
I have an original windshield and mirror on my '69... the mirror in a box of parts on my workbench, it fell off for the previous owner. Probably should mount it, but the visibility is so good being up high, and with the nice big side mirrors, I really haven't seen any need.
