bedliner and sound proofing
Hey Guys I am thinking of putting bedliner for the floor covering but is there a way I can do that and block sound out?
Re: bedliner and sound proofing
I did that in the cab of my truck. I used a spray putty gun ( 2.5 mm. nozzle) that layed it out nicely, not very lumpy. I did it for protection against water leaks and sound proofing. I did put carpet over it.The next thing I am going to do is put inner fender skirts out of a 73 in the wheel house. This should stop the water and dirt from spraying the firewall (making it quietter hopefully). Hope this helps.
1970 ranger 4x4
1965 mustang needs resto
flh shovelhead
rigid evo
flh shovelhead
rigid evo
- Manny
I will recommend the lizard skin stuff. My brother, and i bout the bucket and spray gun then shot the inside of his 89 250 diesel. It is easy to spray lays nice and cleans up with water. Now if you don't have a compressor then bed liner it but the lizard skin was good from my experience..
Her it is
http://www.summitracing.com/search/Bran ... roductName
Little bit higher than i remembers last price has gone up....
Her it is
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
I think the common consensus is that bed liner material is a good place to start but it's not terribly effective by itself at dampening noise. It makes a good platform upon which to stack Dynamat or something of that nature. User Robroy has a good thread detailing his installation of Zilla Mat:
http://www.fordification.com/forum/view ... =6&t=59182
Josh
'72 F-100 Sport Custom 4x4
Manny wrote:I will recommend the lizard skin stuff. My brother, and i bout the bucket and spray gun then shot the inside of his 89 250 diesel. It is easy to spray lays nice and cleans up with water. Now if you don't have a compressor then bed liner it but the lizard skin was good from my experience..
Her it is
