shift indicator
Junior Knight
shift indicator
Post by Junior Knight »
anyone know how to put on the plastic shift indicator on the steering column? :? :?
1967 Ford F-100...goin back *STOCK*..just sayin
mrollings53
Re: shift indicator
Post by mrollings53 »
Bumpside shift indicators were cast as a part of the shift collar. Replacement style ones are ment for dentside trucks, but fit bump columns. These ones have a separate indicator that slides into a slot on the side that faces the driver.
Disregard that. Didn't see what you had meant by shift indicator. I'm pretty sure it screws into the back of the part you bolt the TSS to.
Common Sense is an Uncommon Virtue
Junior Knight
Re: shift indicator
ok..i see that now...thanks
