Got this as an e-mail and thought I'd share.
After every flight, UPS pilots fill out a form, called a 'gripe sheet,' which tells mechanics about problems with the aircraft.
> >>>The mechanics correct the problems, document their repairs on the form, and then pilots review the gripe sheets before the next flight.
> >>>Never let it be said that ground crews lack a sense of humor.
> >>>Here are some actual maintenance complaints submitted by UPS pilots (marked with a P) and the solutions recorded (marked with an S) by maintenance engineers.
> >>>By the way, UPS is the only major airline that has never, ever, had an accident.
> >>>P: Left inside main tire almost needs replacement.
> >>>S: Almost replaced left inside main tire.
> >>>P: Test flight OK, except auto-land very rough.
> >>>S: Auto-land not installed on this aircraft.
> >>>P: Something loose in cockpit.
> >>>S: Something tightened in cockpit.
> >>>P: Dead bugs on windshield.
> >>>S: Live bugs on back-order.
> >>>P: Autopilot in altitude-hold mode produces a 200-feet-per-minute descent.
> >>>S: Cannot reproduce problem on ground..
> >>>P: Evidence of leak on right main landing gear.
> >>>S: Evidence removed.
> >>>P: DME volume unbelievably loud.
> >>>S: DME volume set to more believable level.
> >>>P: Friction locks cause throttle levers to stick.
> >>>S: That's what friction locks are for.
> >>>P: IFF inoperative in OFF mode.
> >>>S: IFF is always inoperative in OFF mode.
> >>>P: Suspected crack in windshield.
> >>>S: Suspect you're right.
> >>>P: Number 3 engine missing.
> >>>S: Engine found on right wing after brief
> >>>search.
> >>>P: Aircraft handles funny. (I love this one!)
> >>>S: Aircraft warned to straighten up, fly right and be serious.
> >>>P:Target radar hums.
> >>>S: Reprogrammed target radar with lyrics.
> >>>P: Mouse in cockpit.
> >>>S: Cat installed.
> >>>And the best one for last
> >>>P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer.
> >>>S: Took hammer away from the midget.
A little airline humor
- wildcard
- 67mann
Re: A little airline humor
wildcard wrote:> >>>S: Took hammer away from the midget.
- PhantomoftheBumpside
Funny, but have seen this attributed to others before UPS, including Air Force, American and Delta...
UPS has had aircraft accidents, including a fatal one in Dubai which was blamed on exploding cargo about a year or so ago.
-- ROB --
The collective money pit details...
-On The Road-
1990 * 1FTEE14YZLHA83xxx ..- 138 E142 __ E 18 __ 3P
-Projects-
-Spares-
-Recently Departed-
1997 - 4M2DU55P9VUJ46xxx...- 112 4 22 _ _ 8 D4 U 1F
1997 - Dodge Caravan
1987 - Toyota Tercel Wagon FWD
1978 - Winnebago Brave (Dodge D800FC)
1970 - F10YRJ80xxx ..............- 131 3 F100 D _4 G 02
1968 - F25YRC99xxx .............- 131 E F253 B 81 G C8
1968 - F25YRD69xxx .............- 131 C F254 E 81 A 24
-On The Road-
-Projects-
-Spares-
-Recently Departed-
