Around the vents is really the only place you can tell it is a cover
Dash - re-cover or replace?
- couchcuts
Re: Dash - re-cover or replace?
Okay so I got a better picture of the molded dash cover.
http://www.fordification.com/forum/view ... 22&t=64227
1970 F100 Custom Wimbleton White 240 c6 shortbed
Had the cover in my 71 since I painted it about 12 years ago. I am happy with it. Much happier since back then a real pad was over $500. Mine has gotten loose once but I just re-glued it. It has stayed nice and flat. Like said, around the vents you can tell it is not an original pad. Other than that you have to look real close to tell.
If I was filthy rich I'd get a real pad. I am not so like what I have
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- rltvader
I have a cover on mine, and i wish I had the money to get a real one, The one I have on it doesn't stick well in the heat and comes up.
I wish I could have done without a pad, but the guy before me hacked up the dash to put speakers in.,
-Built Ford Tough for a Reason
1969 F100 Red/White LWB (302)
1972 F250 Camper Special Ranger White LWB (FE)
rltvader wrote:I have a cover on mine, and i wish I had the money to get a real one, The one I have on it doesn't stick well in the heat and comes up.
Your not alone with a hacked up dash from PO. What were they thinking.
Thanks JP! Ms. Cordova is a factory 1969 Ford F100 Ranger with a 390, Front disc brakes, Cordova copper orange, behind the seat box
I have a cover on both of my 67s and love them for the money.
Not perfect but a lot better than all of those cracks showing.
1967 Ranger,Short bed,390,C-6,9 inch,4 BBL.,intake,cam,headers,3:55 Posi.,A/C,Power steering,Power Disc Brakes,Automatic trans.DJM dropped I-beams,flipped rear hangers,headlight harness upgrade.ExTang tonneau cover "Old Blue".
http://s508.photobucket.com/albums/s328/BigSxy96/
1967 Base model,352,2bbl.,3 on the tree,short bed,3:25 9 inch "Rusty".
1967 Mustang coupe-show car/garage queen.Small Block,alum. heads,Nitrous,4:11Locker,Areospace brakes "Mystang".
1996 F-250 Powerstroke-Big intake,exhaust,injectors.(Nice Smoke Show) "Big Sexy"
