9" versus 9.3" rear axle
Other than the obvious .3, what is the difference between the two, or are they the same?
1949 Ford F-1
1951 Cushman trike
1963 Ranchero
1972 Ranger XLT
1980 Z-28
1985 S-15 4x4
'88 88" Paug (Started out as a '66 74" Shovelhead)
1993 LeBaron GTC
1951 Cushman trike
1963 Ranchero
1972 Ranger XLT
1980 Z-28
1985 S-15 4x4
1993 LeBaron GTC
- Hawkrod
Re: 9" versus 9.3" rear axle
They are similar but different. The 9 3/8 is a 9 inch on steroids. It uses the same axle housing but the housings have to be notched to allow the gears to enter and the 9 3/8 all came with 31 spline axles while the 9 inch can be 28 or 31 spline. The 9 3/8 is heavier duty and was designed for higher torque loads but they never had much of a gear ratio selection so they tend to be unpopular. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
Thank's for the reply. This is good to know. On the tag it states the 9.3 is a 3L50 which works good for my purposes.
1949 Ford F-1
1951 Cushman trike
1963 Ranchero
1972 Ranger XLT
1980 Z-28
1985 S-15 4x4
1993 LeBaron GTC
1951 Cushman trike
1963 Ranchero
1972 Ranger XLT
1980 Z-28
1985 S-15 4x4
1993 LeBaron GTC
- BobbyFord
3L50, 9 3/8" is what came stock in my truck. It's a nice all around ratio.49FordF1 wrote:Thank's for the reply. This is good to know. On the tag it states the 9.3 is a 3L50 which works good for my purposes.
