Speedometer
1970 Hi-Boy
Location: Middle Tenessee/Northern Wisconsin/wherever else I may roam to try and make a buck.
Speedometer
Post by 1970 Hi-Boy »
Does anyone in the wide, wide world of Ford Trucks, know why the speedometer in my 1970 F250 Hi-Boy, has a red line from 70 to 100 mph? So in other words what am I risking if I exceed 70 mph? I can't even find anything about it in the owners manual. Surely Ford must have had a reason for doing this it would stand to reason, I just do not know what that reason is. Looking for the real deal answer, anybody? :?
1970 F250 Sport Custom 4x4 360 V8, otherwise known as the Hi Boy, and a Harley-Davidson.
1953 Lincoln SA200 portable welder with a 4 cylinder 1941 Continental F162 engine.
"If you think you can do a thing or think you can't do a thing, you're right." Henry Ford
Whateverman
Re: Speedometer
Post by Whateverman »
The real deal answer? Dunno.
Some reasonable guesses: as a warning -that you are driving at a speed faster than the drum brakes can safely stop
-that the engine is revving pretty high at these speeds
-that these old trucks get pretty floaty at higher speeds
basketcase0302
Re: Speedometer
Post by basketcase0302 »
1970 Hi-Boy on Mon Mar 19, 2012 10:07 pm
You might not be old enough to remember...
Your truck was made just prior to when the NTSB here in the USA dropped the speed limit nationwide to 55 MPH. So even then over 70 was illegal in ever state.
An educated guess-not "the real deal" by no means... :D
1970 Hi-Boy
Re: Speedometer
Too young for sure, I was born 2 years prior to the truck being built at the San Jose plant, would it being built in California have anything to do with it possibly? :maybe:
71PA_Highboy
Re: Speedometer
Post by 71PA_Highboy »
It is just what Basketcase says... the point at which you exceeded the maximum speed limit.
The older cars have the same thing... and some of them even had dots on the speedo hat told people when to shift too....
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1970 Hi-Boy
Re: Speedometer
I thank you guys for replying. That does make a lot of sense after you mentioned it, I hadn't considered that before. So now I know, I risk a ticket when I'm on the Interstate. Better than all the other horrible possibility's I've conjured up over the years. Thanks again. :D
