dashboard lighting
dashboard lighting
On my 68 f100, the dashlights don't turn on at all. At first I just thought that it was missing the bulbs, but when i replaced my speedometer i noticed that there were light bulbs and i tested both of them, they both work. I'm figuring it's just a problem with the wiring because the headlight switch works perfectly normal, but, only being 14, I figured it would be best to check on here.
- 71PA_Highboy
Re: dashboard lighting
The headlight switch has a potentometer on the front of it... ceramic piece with coils of wire embedded in it, and a slider that contacts it.
Make sure those are good, and test the output to the Blue wire with red stripe (instrument lighting).
Did you turn the knob to make sure that they are as bright as they can be?
Also, there is a fuse to check... 4A IIRC.
Good luck!
Good luck!
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- 1970 Hi-Boy
- Location: Middle Tenessee/Northern Wisconsin/wherever else I may roam to try and make a buck.
Replacing your speedometer raised a flag to me, was the whole thing replaced along with the printed board on the back? These are not interchangeable from year to year, and your wiring harness wont match up. If so you can put just the speedometer head into your old gauge cluster. Just thought I'd check. I learned the hard way.
1970 F250 Sport Custom 4x4 360 V8, otherwise known as the Hi Boy, and a Harley-Davidson.
1953 Lincoln SA200 portable welder with a 4 cylinder 1941 Continental F162 engine.
"If you think you can do a thing or think you can't do a thing, you're right." Henry Ford
- TNIceWolf
That wouldnt be a problem on a 68 I would think. As far as I know all 67-69 used a instrument cluster that was all wired in. No printed circuit involved until 1970 if memory serves.1970 Hi-Boy wrote:Replacing your speedometer raised a flag to me, was the whole thing replaced along with the printed board on the back? These are not interchangeable from year to year, and your wiring harness wont match up. If so you can put just the speedometer head into your old gauge cluster. Just thought I'd check. I learned the hard way.
Presently in the stable
1969 Ford F-350 DRW
1969 Ford F-350 DRW
- 1970 Hi-Boy
You are correct sir, sorry I blew up! It's the 70 vs the 71-72 that doesn't work, my bad.TNIceWolf wrote:That wouldnt be a problem on a 68 I would think. As far as I know all 67-69 used a instrument cluster that was all wired in. No printed circuit involved until 1970 if memory serves.1970 Hi-Boy wrote:Replacing your speedometer raised a flag to me, was the whole thing replaced along with the printed board on the back? These are not interchangeable from year to year, and your wiring harness wont match up. If so you can put just the speedometer head into your old gauge cluster. Just thought I'd check. I learned the hard way.
- mybros71
Doesn't the cluster fuse also cover the tail light circuit?
2006 Mustang GT (Wife's)
1962 Comet Custom (Wife's)
1971 F100 2wd Prerunner Project (Daughter's)
1971 F250 4wd "The Beast" (Son's)
2007 Toyota Tundra 4wd. (Credit Union's)
Seriously, the best truck I've ever owned, without exception.
71PA_Highboy wrote:The headlight switch has a potentometer on the front of it... ceramic piece with coils of wire embedded in it, and a slider that contacts it.
Good luck!
I replaced my headlight switch just recently to fix this very problem, dash lights not working. The spring on the old one was corroded and broken.
- mybros71
There you go.
