rocker shaft tubes
rocker shaft tubes
i am puttting inlifters and pushrods in a 1970 f100 with a 390 , question is do the rocker tube holes go upor down to oil ? the shafts had 1 up and 1 down when i took apart
- 1970 Hi-Boy
- Location: Middle Tenessee/Northern Wisconsin/wherever else I may roam to try and make a buck.
Re: rocker shaft tubes
Here's what it says in my 1970 Ford Shop Manual, and I'll type word for word, the section that is in bold print on this subject in the book. - "Be sure the shaft is positioned so that the oil holes are to the bottom. Also the identification notch on the end of the shaft must be downward and toward the front on the right bank, or toward the rear on the left bank."(page 21-06-08 Volume two-Engines) Hope that answers your question.
1970 F250 Sport Custom 4x4 360 V8, otherwise known as the Hi Boy, and a Harley-Davidson.
1953 Lincoln SA200 portable welder with a 4 cylinder 1941 Continental F162 engine.
"If you think you can do a thing or think you can't do a thing, you're right." Henry Ford
- blumule
down, down, down.
