Modern 5 or 6 speed trans options?????
71_swb
Post by 71_swb »
i am looking to find a 5 or 6 speed trans to put behind my mild 390 into my 71 bump its going to be a street truck not much track time just cruiseing around with the occasionall hard shifting threw gears :D all the research i have found is pointing to a tremac tko or similer trans that cost a fortune :cry: im looking for a trans that is aviable and can handle the power of my 390 i can get a t5 out of a camaro for a good price can a trans like this be built to handle the power? i have looked into the ford zf trans but there geard way to low for my likeing i also considerd the mazda m50d R2 trans any other opions im missing? any feed back will be greatly appreciated!
1971 F-100 SWB Styleside 460 C6 8 mpg
1970 El Camino 355 13.25 @ 106
averagef250
Re: Modern 5 or 6 speed trans options?????
Post by averagef250 »
T56 seems like the single reasonable solution for what you want.
Car trannies in trucks is a gray area. If you use the truck like a truck you blow them apart.
67F100-390
Post by 67F100-390 »
averagef250 wrote:T56 seems like the single reasonable solution for what you want.
So if I wanted a t56 and didn't use my truck for hauling or pulling anything, I would be ok?
67 F-100 Custom Cab Short Bed
428ci 4 speed
Finally runs and drives after 14 long years in a field
averagef250
They aren't weak transmissions, just made for a completely different use. You can bang gears with 1000 HP in a 3000 pound car and a 150 pound car transmission will hold it fine. If you put 150HP and 400 lb/ft of torque through that same transmission pulling trailers around it won't last long at all.
HIO Silver
Post by HIO Silver »
A WC T5 won't last behind your 390. Here is a vendor for a ZF5 to FE adapter: http://www.high-impact.net/zf_5&6spd.htm
Regardless of which way ya go, it's gonna cost upwards of $2200 to $3000. Personally, I would go with a new TKO-500 and a QuickTime bellhousing ...don't forget to add a new clutch and flywheel.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
sargentrs
Post by sargentrs »
I've heard good things about these. http://www.fordification.com/tech/M5R2_5spd-swap.htm
Ranchero50
Post by Ranchero50 »
Yep, the Tremec 3550's or TKO's have great gearsets, about 2x the T5 gearsets in tickness and the shaft spacing makes the torque rating.
