Column shift to floor conversion
Looking for opinions on going from a 3speed column shift to a floor shifter, any pros/cons and how's Everyones experiences been with installation and function
I have a 68 with a inline 300 btw if it matters, not sure on the trans model though.
Thanks everyone!
Thanks everyone!
72 lwb sport custom, 300/3spd
pdb,ps, ac 3.70:1
68-swb 300/3spd sold
69-lwb 390/c6 sold
69-swb 240/c4 sold
72-swb ranger xlt 360/c6 sold
72-swb sport custom 302/3spdsold
pdb,ps, ac 3.70:1
69-lwb 390/c6 sold
69-swb 240/c4 sold
Re: Column shift to floor conversion
My 68 was converted to a floor shifter before i got it. It has a weird shift pattern on it. It shifts pretty crappilly too. I'm not sure if it's just mine of if that's with everybody's.
The shift pattern
1 3
I--I
R 2
If someone else can confirm that, then that might be the same pattern as everybody else's who converted from a tree to a floor.
The shift pattern
1 3
I--I
R 2
I wondered how the pattern would go . I learned how to drive on a standard many years ago, I've never driven a 3 on a tree tho.. Currently mines in need of a engine rebuild and I thought it would be a good time to install a floor conversion plus my column is worn badly around the original mechanism.
pdb,ps, ac 3.70:1
69-lwb 390/c6 sold
69-swb 240/c4 sold
pdb,ps, ac 3.70:1
69-lwb 390/c6 sold
69-swb 240/c4 sold
My 3 on the tree converted to floor shift is:
R 2
1 3
I didn't do the conversion but thats what I got when I bought it. It shifts crappy to me too. I'd rather have it on the column.
R 2
1 3
1968 F100 Ranger 390/C6 Lunar Green/Wimbleton White (Driver)
1968 F100 Ranger 360 Borg Warner OD Lunar Green/Wimbleton White
My truck had a Hurst 3 sp shifter in it, once it was adjusted right, it shifted real smooth. A floor shifter out of adjustment or with wore out bushings wont be any better than a wore out column shifter. With everything in neutral position, there's a hole for a pin on the tower to align the levers up, if you don't have a pin, an allen wrench will work. At that point adjust the rods so they slip in & out of the tower levers. The cheap plastic bushings can be replaced with steel to give a better feel. It should have a normal H pattern as the column shifter had.
68bumps, it sounds as though the levers on your tranny are upside down, flip them over and readjust the shifter.
I'll check into that, thanks!
pdb,ps, ac 3.70:1
69-lwb 390/c6 sold
69-swb 240/c4 sold
pdb,ps, ac 3.70:1
69-lwb 390/c6 sold
69-swb 240/c4 sold
Well, if i were keeping the trans, i'd do that, but i'm not. I'm switching out the engine and trans to a 302 with (hopefully) a 5 speed.68shortbed wrote:My truck had a Hurst 3 sp shifter in it, once it was adjusted right, it shifted real smooth. A floor shifter out of adjustment or with wore out bushings wont be any better than a wore out column shifter. With everything in neutral position, there's a hole for a pin on the tower to align the levers up, if you don't have a pin, an allen wrench will work. At that point adjust the rods so they slip in & out of the tower levers. The cheap plastic bushings can be replaced with steel to give a better feel. It should have a normal H pattern as the column shifter had.
What type of trans is this? I understand the automatics and pan sizes but how does ford name or classify the manuals in bumpsides? Light duty??
pdb,ps, ac 3.70:1
69-lwb 390/c6 sold
69-swb 240/c4 sold
pdb,ps, ac 3.70:1
69-lwb 390/c6 sold
69-swb 240/c4 sold
I'm currently looking to swap to a floor shift version myself... However, I want a 4 speed (perhaps a top loader 'box) conversion before I do it so I can get a little more economical mileage out of my 1970 f100 Ranger (I do intend to put a taller final drive gearset in with the new 'box to actually pull that off.)
I'm not here to just hijack a thread (I apologize in advance to the mods if that happens) but can someone point me to a thread where someone is doing a 3 speed to 4 speed conversion?
I have been researching the 3 speed conversion and I found out that Hurst discontinued their assembly kit for 67-72 F100 Part #HUR3670027. The universal kit is available through Hurst but it takes some effort to install from what Ive read.
