I have several threads going in different sections as I am trying to start my 68 with a 240. I have (borrowing from a friend) a C4 trans from a 74 mustang. I am thinking of mounting the C4 to the motor without installing the torque converter. I will not have any linkage hooked up and I will not have a driveshaft installed. I am simply using this transmission to bolt the starter in and act as the third support for the motor.
Without the torque converter there is nothing actually enganging the motor & trans toghether, right?...So, I'm thinking it should be fine.
I don't want to spend the time / money filling the trans & converter with fluid, installing the converter, and bolting it to the flywheel only to find that the motor won't start. At the same time, this is a buddy's trans that I do not want to damage.
Let me know your thoughts.
Installing trans without torque converter
- marvin2
- TNIceWolf
Re: Installing trans without torque converter
Shouldnt do any damage at all to the trans or engine.
Presently in the stable
1969 Ford F-350 DRW
1969 Ford F-350 DRW
- basketcase0302
- marvin2
Awesome...I can't wait to get everything hooked up and try again. Thanks for the input guys.
way better than the jackstand under the bellhousing idea!
No reason you should have any problems. I would take the input out of the transmission first as there is nothing holding it in place if the converter is not installed. You really don't want the input accidentally "walking" into the back of the crankshaft.
Or, if you have any loose bell housing, just use only the bell.
