C4 Help
C4 Help
Hey guys i just bought a new 70 F100 project/daily driver. Its a 302/C4 but every once and awhile it'll make a noise like a squeal with a slight grind it olny lasts maby a second and seems todo it when i gas it kinda hard while turning. I drove the truck home almost 80 miles and it olny did it twice once when iwas turning around or gassed it from a dead stop round a curve. The fluid looks fine,clean and is olny a drop or two at most low and the truck shifts out fine through every gear. Any help/ideas on whats goin on?
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
Re: C4 Help
Doesn't sound like a transmission problem to me. I would look at your front wheel bearings first on the side which is outside on a turn.
- BobbyFord
Re: C4 Help
I would check rear axle bearings, also.
Re: C4 Help
Thanks guys I gotta do brakes so I'll check all that when I tear into it. It did it once again this morning I did a little showing off with my posi track in the driveway andmy drives a steep hill and it shifted outta first made the noise then went right into second and I drove the truck around and its still shifting a ok.
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
Re: C4 Help
( a steep hill and it shifted outta first made the noise then went right into second and I drove the truck around and its still shifting a ok.)
Does this happen during the 1 / 2 shift ? Can you relate it to the shift into 2nd gear....Do the wheels have to be turned for this to happen ? Or does it happen on a straight drive away start? Wheels straight ahead?.......
- BobbyFord
Re: C4 Help
Dry u-joints can also make a similar sound.
Re: C4 Help
Donnie wrote:( a steep hill and it shifted outta first made the noise then went right into second and I drove the truck around and its still shifting a ok.)
It seems to only happen when the wheels are turned to the right. I took it out on another drive this evening and I went out and it shifted manually 1,2,D no problem and I punched it on both flat and hills with no noise. Til I made the right turn and started climbing the hill it made the noise and got bout half way up and tapped the brakes to make a left into my parking spot no noise but the brakes got super squishie and the front chamber was bone dry...could this have something todo with the noise?
Bobbyford- The u-joints are on tomorrows check list cause I got a clunk when I drop it and gear.
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
- J_Boo
Re: C4 Help
I've never had anything like this with a C4, but my AOD I did from a swap does this. So It could be possible, but I would definitely check other things especially those ujoints and the diff. Possibly the power steering pump? I had one that sounded just like that.FordTruck wrote:Hey guys i just bought a new 70 F100 project/daily driver. Its a 302/C4 but every once and awhile it'll make a noise like a squeal with a slight grind it olny lasts maby a second and seems todo it when i gas it kinda hard while turning. I drove the truck home almost 80 miles and it olny did it twice once when iwas turning around or gassed it from a dead stop round a curve. The fluid looks fine,clean and is olny a drop or two at most low and the truck shifts out fine through every gear. Any help/ideas on whats goin on?
Re: C4 Help
Thanks for the replies guys....im also starting to think its not my trans ive had nothing but bad luck with autos in bumps so im a little paranoid about transmissions
but ive been dealing with a week long brake ordeal so i aint done awhole lot tracking down the problem but i did notice the carrier bearings in bad shape so im gonna start with that and u joints
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
