Steering Col. question for you guys with Automatics
- Comet
I am in the process of installing an AT col. in my hiboy for future upgrade to C6 (they didn't come with ATs). I swapped a buddy for his '73-'77 col. because he wanted to go with a stick.
Anyway, since this was not a factory option, but I want it to appear that way, I am in the midst of interchanging 67-72 and 73-77 steering col. parts. I have a question on the AT cols. Does the PRNDL trans. shift dial (the clear plastic indicator on top of the col.) light up like they do on later models when the head lights are on?
That's MR. Jackass to you fellah!
re: Steering Col. question for you guys with Automatics
Nope.
- 71-F-250SC-72-F-250C
I thought the 73-79 did. I am not sure I have never driven a 73-79. Either way the clear plastic deal is not hard to see at night anyways.
71 f-250 Sport Custom-frame off in progress..again thank to irjetmachanic. ![Smile :)](./images/smilies/icon_smile.gif)
72 f-250 Custom
71 f-100 swb sport custom
03 mach1 mustang
[quote="ToughOldFord"]
72 f-250 Custom
03 mach1 mustang
- Comet
- Comet
Oh, one more question. On the shift collar. If I recall, the whole collar rotates (as opposed to 73-79s where just the assy inside the collar and a pin outside rotate), and there is a little pointer cast into the collar. Is that correct? Later they had a plastic pin.
A related question......my '70 with aotomatic usually won't start unless I move the shift lever all the way (as far as it will go)into PARK.What can I do to alleviate this?Thanks...........
- 1970F250
yesComet wrote:Oh, one more question. On the shift collar. If I recall, the whole collar rotates (as opposed to 73-79s where just the assy inside the collar and a pin outside rotate), and there is a little pointer cast into the collar. Is that correct? Later they had a plastic pin.
the light from my tach lights up the plastic thing pretty good
binder56jd wrote: If you can't dazzle them with diamonds- baffle them with b------t
- Comet
Thanks 1970F250. So yes on my question about the shift collar, right?1970F250 wrote:yesComet wrote:Oh, one more question. On the shift collar. If I recall, the whole collar rotates (as opposed to 73-79s where just the assy inside the collar and a pin outside rotate), and there is a little pointer cast into the collar. Is that correct? Later they had a plastic pin.
The early collars had the pointer cast into the collar, whereas the later collars had a notch cut into the top for a slide-in pointer. I'm not sure what the cut-off between the two styles were, but I believe it's a '67-'69 vs. '70-'72 thing...but don't quote me on that.
![Image](http://www.fordification.com/board/shiftcollars.jpg)
- rjewkes
my 77's column shift colar was identical except that the clear plastic PRND12 Was a little thicker.
- Comet
Keith, from the parts catalogs I've seen, I think 1971 was the cut over (but I noticed errors in some of the info., so who knows). Capeclassics said he has a '70 with AT, maybe he can chime in.
Rjewkes, the '77 looks identical, except for what you pointed out and a cover over the clear plastic PRND12 (often times missing) and also the hazard button on the col. instead of the dash.
- rjewkes
Yup. i know my 72 is the rh one in keith's picture. Yeah i put my cover on the 72 it looked nice but even after modifying it it still got knocked around by the lever. ![Laughing :lol:](./images/smilies/icon_laughing01.gif)
- hmills
I am replacing my '71 shift collar. The original shift collar is the one with the indicator built in as in the photo on the left. I ordered a new one from Dennis Carpenter and it came in last week. It has the notch in it (as in the photo on the right) for the clear plastic pointer which I had to order separately. I presume my old shift collar was the original so this may answer the question as to the cutoff for the old versus new style shift collar.
Oh and by the way, getting that roll pin out was not easy. I used three large nuts taped together (I like the socket idea better) on one side of the roll pin and a large nail (about the size of the inside diameter of the hole), a large hammer a few choice words and alot of patience and it finally came out.
Herb
'71 F100 Sport Custom; LWB 302/Auto
